1978 - 1996 Big Bronco
temp sensor
Old Sep 10, 2003 | 10:12 PM
NJbronco138's Avatar
NJbronco138
temp sensor
From what I have read in the archives a 351w has two temp sensors. the one by the thermostat housing is for the gauge in the dash the other is for the computer. where is the one for the computer? can I get to it to change it without it being a major project? thanks in advance
Old Sep 10, 2003 | 10:54 PM
DW2455's Avatar
DW2455
temp sensor
yup it should be right there a bout a 1/3 back on the intake from the front, dam i dont know how to explain it ! it should be on the drivers side of the plenium between the front and they midway point. hope this helps? DW
Old Sep 10, 2003 | 10:56 PM
NJbronco138
temp sensor
Isn't that the one for the gauge?
Old Sep 11, 2003 | 12:14 AM
DW2455's Avatar
DW2455
temp sensor
the one for the gage should be right by the front, i think the gage one is smaller in dia, it too late tonight but if i remeber in the am i'll go look at mine and refesh my memory. DW
Old Sep 11, 2003 | 12:04 PM
NJbronco138
temp sensor
Ok i found the right one. thanks for your help DW
Old Sep 11, 2003 | 02:42 PM
frogger01's Avatar
frogger01
temp sensor
Just to clarify the one next to the intake plenum on TOP of the intake manafold is the Air temp sensor. The one on the screw-in nipple just above the T-stat where the TB heater hose goes into is the Water temp sensor. That is the one that goes to your gauge.
Old Sep 11, 2003 | 03:35 PM
NJbronco138
temp sensor
Ok I linked a picture of the sensor I was looking at for the water temp. I know there is the small sensor by the T stat housing for the gauge. I want to change the water temp sensor for the computer.
http://www.members.aol.com/mrccusm/sensor.jpg
Old Sep 12, 2003 | 01:51 AM
greystreak92's Avatar
greystreak92
temp sensor
Temp sensor for the computer should be a two-or three wire connector. The one for the gauge is a single wire.
Old Sep 14, 2003 | 01:43 AM
NJbronco138
temp sensor
Is the sensor for the computer near the gauge sensor? I am looking around all over and not see it.
Old Sep 14, 2003 | 06:10 PM
greystreak92
temp sensor
The coolant temp. sensor for the computer faces the front of the engine AT the front of the engine just above the water neck for the thermostat. It threads into a fitting in the lower intake plenum. Its a two-wire connector with a LT GRN-RED wire and a GRY-RED wire coming from it.
Old Sep 14, 2003 | 07:01 PM
NJbronco138
temp sensor
thanks greystreak, I will go out tomorrow asap and change it out. I am hoping this will take care of that miss
LeoJr
Jul 7, 2016 07:36 AM
oneowner83
Dec 12, 2013 12:28 AM
fitter70737
Dec 30, 2010 10:18 PM
MEATLOAF
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jul 29, 2004 08:20 PM
