Mini-Subwoofer Installed
Old Nov 2, 2017 | 02:56 PM
mojakus's Avatar
mojakus
Quick couple of pics showing how I set up a Kicker Hideaway 11HS8 powered sub in the Ex.
Ran power from from the battery through the firewall, then down along the passenger-side in the door sills, then up and under the carpet to a small hole below the seats. Picture shows the grommet over the hole where the cab is bolted to the frame. Picture is of the DS grommet cap, but I ran it through the passenger side. The battery cable included with the Hideaway was just long enough.
Then I ran aftermarket RCA cables, remote control wire and remote power control wire up the drivers side, under the dash and to the head unit. Grounded to the truck frame under the middle-seat seatbelt receivers. In terms of mounting the sub itself, I drilled two holes in the seat cross-bar that runs under the 60% side, and used two of the mounting brackets that came with the sub to affix it to be crossbar using some small nuts and bolts from the hardware store. I put a cloth under the bar to reduce vibration.
Placed the remote control on the removable under-dash cover for now.
The sub sounds pretty decent for what it is. Tough to hear a huge difference in regular pop/rock (mostly just more depth), but makes electronic and hip-hop come alive. Packs a punch without sacrificing any cargo space. The unit is low enough that I can flatten out the second row no problem.
Old Nov 2, 2017 | 03:42 PM
gwh1bass's Avatar
gwh1bass
Nice, do you have the stock head unit?
Old Nov 2, 2017 | 03:53 PM
mojakus's Avatar
mojakus
I’ve got a cheapo double-din box by Planet Audio. It sounds totally fine and clearly is a copy of higher-end technology with cheaper parts, since it has all the connectors you want (RCA out, two video outs, sub power control, sub outs, reverse wire etc....). $120 with a backup camera, on amazon. Same model as the Boss brand. Looks ok:
Old Nov 3, 2017 | 11:58 AM
Blakshukvw's Avatar
Blakshukvw
Any chance this will fit under 2nd row bucket seat?
Old Nov 3, 2017 | 03:04 PM
gwh1bass's Avatar
gwh1bass
Thanks for responding. I asked because I still have the stock radio and wondered how you pulled the signal for the sub. The Kicker looks like just what I would want, something to add a bit of low end punch, not to rattle the windows.
Old Nov 27, 2017 | 07:45 PM
Swamp Monkey's Avatar
Swamp Monkey
Nice install. Looks clean.
Old Nov 28, 2017 | 06:29 PM
gwh1bass's Avatar
gwh1bass
Will the second row seat still fold down????
Old Jul 11, 2018 | 10:57 AM
BannerAuto's Avatar
BannerAuto
Just giving this post a bump, we still have a few of these left at discount price. If your truck is 2018+, please send the VIN to confirm functionality. PM for pricing, and include your zip code.
Thanks,
Mel
BIGDZL
6.7L Power Stroke Diesel
17
Apr 11, 2018 11:29 AM
audioguru76
66
Apr 8, 2017 06:07 PM
jbellio
Escape & Escape Hybrid
Mar 11, 2013 02:37 PM
ajs 250
Sep 16, 2010 08:44 AM
CruiserClass
Aug 23, 2007 05:25 AM
