Forged Papers - Chronicles of "Dan" the 85 F-250
DMV's and LEO's do not go by the Certification Label VIN to register vehicles. They go by the hidden frame VIN
A common problem is that some people replace damaged left doors with used doors.
The VIN and codes on Certification Labels and Warranty Plates (1963/79) that are affixed to these doors no longer match the vehicles.
I will have to crawl under the truck and look for the frame rail plate.
Agree that I should see X instead of F but since I don't need inspections, they just rolled the title over to me.
Everything else with the truck matches. Even the color code. That is why I was coming up with some far fetched theories.
Okay, I’m thoroughly confused. On my ‘84, the big tag (same format as the pic posted by James) is on the cab structure, above the door latch. There’s no tag I can see on the door itself.
What does firewall vin say?(that is screwed on so not hard either)
The Certification Label is composed of an outer clear layer over the inner printed label.
If people attempt to peel it off, some of the outer layer will peel off, sometimes taking some of the inner layer along with it.
If you erect a cofferdam around it, then fill it with water, the entire label might peel off, but this will take months to occur.
If the label was damaged by an accident or fire, FoMoCo would supply a new label, but it was a PITA rigamarole to obtain it.
For one thing, a police report was required. I know, because I did this...multiple times...when I was a P/M
Some of these truck will have a "buck tag" affixed to the firewall. Buck tags were used by assembly line workers to assure the correct parts are installed that match the build sheet.
Excepting the VIN, codes on buck tags cannot be decoded.
#29
Does not even have to take 30 years!
When I worked at a dealer ship I have seen a new car right off the truck as a Dodge Aspin on 1 side and Plymouth Volare on the other side.
Had to check the VIN to see just what make & model to was and then change the badging to match.
See if someone knows where the VIN is stamped on the frame and see if it matches everything else.
Dave ----
Dave ----
#30
Heard it is on the passenger rail before the front cab mount. Tried to look and didn't spot anything. We'll see it when it comes time to do the body work and take the cab off.
