Sponsored by: Real Truck
Front Brake Pad Replacement
Old Sep 10, 2003 | 09:01 PM
katydid66's Avatar
katydid66
Folks,
Can anyone tell me if I use the age old method of retracting my calipers with a C-clamp...or is there a different way of doing this with an 1999 F-250? I here that some Fords have a special tool to do this now?
I have to replace the front pads.
Katydid66
Old Sep 11, 2003 | 03:36 AM
V10F250's Avatar
V10F250
I think what you are talking about is the rear disc brakes. The front are the same as they have been for years. The only reason the rear is different is the e-brake. If you do the rears, there is a tool that is square with pins that goes on a rachet and turns the calpier piston back into the caliper. So, the C-Clamp method will work. However, just check very well for leaks. Don't put the new pads on the caliper if it is leaking. Then, you will need to rebuild the caliper.
Old Sep 11, 2003 | 06:48 AM
jschira's Avatar
jschira
I replaced my rotors and pads all around with ART rotors.
I used a C-clamp.
Worked just great.
Don't own a fancy tool. Even my C-clamp has seen better days.
Old Sep 11, 2003 | 06:53 AM
Bob Ayers's Avatar
Bob Ayers
One other thing, with ABS, DO NOT push the old brake fluid back
into the system when you push the pistons back in the calipers.
Open the bleeder to force the old fluid out there.....
Old Sep 11, 2003 | 07:56 AM
katydid66's Avatar
katydid66
Gentlemen,
Thank you for all advice. I will be replacing front rotors, back rotors, back calipers, e-brake and pads....I figure this will take me a while, as I know this will not go real well!! This truck of mine eats brake systems like a child eats candy. I cannot afford to pay to have all of this done, so I am going to study up a bit, and ask for advice...and then plunge in! You will probably see me back here intermittently...begging for tech help.
Kate
Steven Day
1997 - 2003 F150
Aug 18, 2015 07:58 PM
66low
Feb 20, 2015 11:28 AM
Mark T-TB
19
May 5, 2014 10:13 AM
Greg230
Jul 19, 2006 01:59 PM
lt
Apr 12, 2001 10:01 AM
