Bolt Lock Pin
Old Nov 1, 2017 | 10:44 AM
jaherbst's Avatar
jaherbst
Bolt Lock Pin
Just installed my new Bolt Lock receiver pin that is automatically keyed to your glove box key on your Key Fob. (push buttons start)
Looks Good works Good.
Ordered through New Level Motorsports in San
Diego. newlevelmotorsports.com. model # 7023585 $19.99
Now no extra key for the Hitch Lock pin.
Jack
Old Nov 1, 2017 | 11:04 AM
ERock62's Avatar
ERock62
I have the same. Works great!
Also bought some of their regular locks that are keyed to my truck key and use them on my toy hauler.
Old Nov 1, 2017 | 11:52 AM
grege's Avatar
grege
For those with push button start, is it a pain to get the key in your fob out to open the lock?
I use Bolt with my F150 but it's a keyed start so the key is always out. I did get a spare non starting key made for my F150 so was thinking of getting a couple more made and just using that for my Bolt locks. Would be cheaper since I wouldn't have to replace the locks.
Old Nov 1, 2017 | 02:26 PM
ChrisGTA's Avatar
ChrisGTA
Just to clarify. The Bolt lock WILL work with this key from my key FOB?
I have the Extang bed cover with a Bolt lock and was told by my supplier that it would not work.
Old Nov 1, 2017 | 04:28 PM
FishRanger's Avatar
FishRanger
Does this fit the 3" receivers? Couldn't find the length.
Old Nov 1, 2017 | 05:21 PM
johnso's Avatar
johnso
I called the company and they said yes it would work, so now I'm not sure, if it doesn't I'll just return them. I explained that I had the same key fob you show and that the key pulled out of the fob. And they said it would work. [Fingers Crossed] should have it in a day or two if you want to hold until I can confirm it.
Old Nov 1, 2017 | 05:29 PM
ChrisGTA's Avatar
ChrisGTA
Thanks for the reply. I'm going to wait and see how it works for you. I can't return this bed cover. If it doesn't work I'll either leave it un programmed or use my spare key from my old GMC.
Old Nov 1, 2017 | 07:28 PM
jaherbst's Avatar
jaherbst
Yes it does. I have a 3" inch hitch.
Jack
Old Dec 29, 2017 | 09:55 AM
FishRanger's Avatar
FishRanger
Anyone confirm this works with the fob key?
Old Dec 29, 2017 | 11:22 AM
1956Fatfenders's Avatar
1956Fatfenders
I too have the Bolt Lock receiver pin and the Extang tonneau cover with the Bolt Lock lock. Nothing nicer than not fumbling for, or remembering which key goes where. One key does it all. I do not have the push button start, so its a little easier for me.
Old Dec 29, 2017 | 11:34 AM
RPFB's Avatar
RPFB
Amazon says that
7023585 7023585
is for Ford side cut keys, so it should work on the 2017 and 2018 keys. PN
7018447 7018447
is for the older keys.
Old Dec 29, 2017 | 03:04 PM
bushpilot's Avatar
bushpilot
I got tired of futzing w/ keys....
Old Dec 29, 2017 | 07:15 PM
jaherbst's Avatar
jaherbst
Yes
Jack
Old Dec 30, 2017 | 11:49 AM
Sleeper73's Avatar
Sleeper73
Yes it works with fob key, and with 3 inch. Works great and don’t have to worry bout another key
Jonathan
EXv10
Nov 8, 2013 10:30 AM
GamerGirlAlice
16
Sep 27, 2013 10:14 PM
Greywolf
All Things Towing
65
Jan 29, 2012 01:31 PM
kupiec20
Mar 27, 2010 12:50 AM
