Intake question
Old Oct 31, 2017 | 12:07 PM
joe blow's Avatar
joe blow
Intake question
I feel dumb for even asking but has anyone changed the intake manifold without removing the turbo?
I have never tried it but it seems that if you unbolt the EGR cooler off the intake tab in the rear remove the long studs that hold it up against the front of the manifold, you'd be able to snake it out.
Anyone accomplish it this way?
I am going to install my new ported intake from ODAWG and really don't want to tear the top apart AGAIN
Old Oct 31, 2017 | 12:15 PM
jswartz84's Avatar
jswartz84
Does your connect in the back or is it the newer horseshoe looking intake?
Old Oct 31, 2017 | 12:17 PM
joe blow's Avatar
joe blow
It is the newest style...not the late '03
It does connect in the back through a hole casting in the RH side rear of the intake...basically a support
Old Oct 31, 2017 | 12:20 PM
jswartz84's Avatar
jswartz84
It seems worth trying. Only hang up I can think of is accessing the rear intake bolts, the exhaust up pipes might interfere with removal of them.
Old Oct 31, 2017 | 04:31 PM
joe blow's Avatar
joe blow
I haven't really looked at it to devise an action plan. Wish I would have known I'd be fighting egt's I would have done this from the get go
Old Oct 31, 2017 | 09:01 PM
jetjockey99's Avatar
jetjockey99
I have done it, first time it was very tight getting it out, my truck is an '03 that I put an '05 manifold on when I did the EGR delete, the second time it was easier because I cut the tab off on the passenger side that the EGR bolted to which gave me more clearance, it was tight but doable, I did leave several of the rearmost bolts in the manifold because there was no clearance to remove them. It was actually harder to replace it although not to bad.
Old Oct 31, 2017 | 10:08 PM
chetspencer's Avatar
chetspencer
I have a 4" downpipe which makes it impossible to remove the last rear bolt on the passenger side of the intake manifold without removing the downpipe v band. After rebuilding my turbo, I'd say anytime is a good time to clean the unison ring and once you've taken the turbo out 3 or 4 times it's no big deal.
Old Oct 31, 2017 | 10:22 PM
joe blow's Avatar
joe blow
Thanks for the replies. It seems the tab will fight me and the last thing I want is to have a coolant leak trying to shortcut it
ill take the turbo out and do it right.
Thanks
joe
microdevil45
Dec 21, 2011 10:45 AM
Green Streak
Jan 9, 2006 09:23 AM
marty68
Jun 22, 2005 04:56 AM
kilroy99
Jan 13, 2005 09:27 PM
