TPMS how accurate?
Old Oct 31, 2017 | 11:28 AM
Rockinfigs's Avatar
Rockinfigs
TPMS how accurate?
How accurate are the stock TPMS that come on the 2017 f250/350.. Should I just use them as a guide n actually use a digital tire pressure reader?
Old Oct 31, 2017 | 11:42 AM
roadpilot's Avatar
roadpilot
The newer (2008?) direct pressure sensors are usually pretty accurate (1-2 psi). That said, I would only use TPMS to warn you of a puncture or an active air leak. You should check your tire pressures at least once a month or so with a gauge you know is accurate.
Old Oct 31, 2017 | 01:35 PM
tibadoe's Avatar
tibadoe
Just checked mine against a gauge and they were all dead on except one. That one was off by 1 psi. Surprisingly, a little more accurate than I thought.
Old Oct 31, 2017 | 01:53 PM
ChrisGTA's Avatar
ChrisGTA
If your using an old school stick gauge it's likely that the gauge is far less accurate than the sensors. I've had new Schrader gauges off by 5-10 psi. Invest in a decent digital gauge.
Old Oct 31, 2017 | 02:29 PM
wfedwar's Avatar
wfedwar
All mine are within a PSI of what my gauge reads.
Old Oct 31, 2017 | 03:48 PM
Uzumati's Avatar
Uzumati
Same here, not using a stick gauge
Old Oct 31, 2017 | 04:02 PM
bowler304's Avatar
bowler304
How quick do they update?
Old Oct 31, 2017 | 06:54 PM
17 Oaks's Avatar
17 Oaks
Fill tires until it reads what you want to run.
Then check with a dial or digital guage, if its off, air up/down to get what you want (IF you trust YOUR dial more than the TPMS).
Either way you trust make a notes on each wheel:
Dial reads 60 psi
TPMS reads 64 psi
You wanted 64 but you have put your TRUST in the dial, so you ADD 4 lbs to read 68 and now your dial reads 64
OR
You can trust the TPMS like I do and I have run the numbers several times and its +/- 1 lb every time...your mileage and psi may be different.
Country_Mouse
Mar 15, 2020 08:39 AM
Larrymac52
Feb 21, 2018 10:04 PM
weedwacker4242
Mar 6, 2017 10:10 PM
asok
Jun 22, 2011 08:30 AM
73cntry
27
Nov 29, 2010 08:02 PM
