Sponsored by: Real Truck
DTC's question
Old Oct 31, 2017 | 08:49 AM
akmikek's Avatar
akmikek
DTC's question
I have used AE to pull a few codes from my 99 F250 CC SD and i am wondering if anyone has any ideas.
I get C1226 Lamp Brake warning short to ground
B1352 ignition key circuit failure
B1300 power door lock circuit failure
B1892Airbag tone warning
B1869 lamp air bag warning
The service engine light also goes on and off repeatedly.
Back story is i had a leak in the pillar that dropped water on the fuse block. I removed and tore down and rebuilt the fuse block. The GEM didnt look as if it was wet at all and no obvious corrosion or burns.
The day that i reinstalled the fuse block the interior light #1 relay was clicking away but it has since stopped.
Is it possible that it could be a bad ground somewhere? Or possibly a bad ignition? I was having the battery drain and the ABS and airbag light stay on but know they are not. It starts hard but seems to run fine?
Thanks for any help.
newberrystreet
Jan 27, 2013 09:55 AM
camperspecial65
27
Feb 23, 2010 11:47 PM
meramec8n
Jun 20, 2008 09:17 AM
CJK440
1997 - 2003 F150
Apr 10, 2006 04:11 PM
