Seat replacement
Old Oct 29, 2017 | 12:23 PM
Jeff53's Avatar
Jeff53
Seat replacement
I was wondering if anyone has ever swapped all three rows of seats from a GM (Tahoe, Suburban/Yukon) into an Excursion? I love the Ex, but the seats in my Avalanche were much more comfortable and had a lot more adjustment to them than the Ex does. I realize that it's likely not a simple bolt-in, but was just curious as to how much work it would be.
Old Oct 29, 2017 | 01:34 PM
mecdac's Avatar
mecdac
Have you considered upgrading to Limited or Eddie Bauer seats?
Old Oct 29, 2017 | 02:01 PM
Jeff53's Avatar
Jeff53
I've looked for them on Craigslist
People seem to want a small fortune for the Ford seats when they can be found. The GM seats seem to be cheaper and more plentiful around me. Is the seat structure any different in the Limited and Eddie Bauer than the cloth power seats that I currently have? If the structure is the same, then comparing the two, I found the GM seats to be more comfortable overall, especially for long drives.
Old Oct 29, 2017 | 02:34 PM
Oldguyfl's Avatar
Oldguyfl
If I were ever to swap out front seats, I would chose seats from a 2004-06 GTO. Those are the most comfortable and sporty seats a factory ever made. They look great too.
Old Oct 29, 2017 | 03:34 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Originally Posted by Jeff53
If the structure is the same, then comparing the two, .
F250 and Excursion Seat frame and cushions are the same other then heated vs no heated.
The only thing that changes between trim models is the cover.
Old Oct 29, 2017 | 04:11 PM
Jeff53's Avatar
Jeff53
That's what I thought
But, not being an expert, I wasn't sure if they may have put more padding in the upscale models than what was in the XLT. Thanks for the info.
Old Oct 29, 2017 | 07:42 PM
fordboy2's Avatar
fordboy2
Only upgrade from ford might be the 11 and up super duty seats.
Old Oct 30, 2017 | 04:22 AM
unleashd's Avatar
unleashd
Here's an option....https://baltimore.craigslist.org/pts...340688420.html
Old Oct 30, 2017 | 06:30 AM
Jeff53's Avatar
Jeff53
Thanks
I'm kind of looking to spend a few hundred with my labor vice a few thousand. I'll probably end up with what I have. I was just trying to see if anyone had ever swapped in the GM seats since I seem to be able to find them for a lot less than the Ford seats and I know that they are comfortable from personal experience.
Originally Posted by unleashd
Old Oct 30, 2017 | 08:56 AM
unleashd's Avatar
unleashd
Unfortunately around our area here in NoVA, we pay premium prices for these parts. BTW, if you want to pick up something cheaper with quite a bit of DIY, here's a set of seats and door panels. I pinged him about splitting the setup to get just the door panels but he has not responded back. If interested, we can buy together and split the cost.
https://easternshore.craigslist.org/...355101132.html
Old Oct 30, 2017 | 09:09 AM
mecdac's Avatar
mecdac
@unleashd
Prakash, you know that only the front door panels will fit, right?
Old Oct 30, 2017 | 09:23 AM
WE3ZS's Avatar
WE3ZS
Yep, it takes four SD rear door panels, a lot of cutting and finishing to make one set of late model EX rear door panels. The EX rear doors are longer than the crew cabs.
Old Oct 30, 2017 | 09:32 AM
unleashd's Avatar
unleashd
@unleashd
oooops...double posting
Old Oct 30, 2017 | 09:33 AM
unleashd's Avatar
unleashd
@unleashd
Yes....
I was going after the front door panel for the sake of the newer style switch panel for my power fold-telescope-heated mirrors.
Old Oct 30, 2017 | 09:35 AM
unleashd's Avatar
unleashd
IIRC, I had read about this in one of the threads earlier....was it Nicmike or 5HUB???
