D5AE 351 heads on 94 shortblock? pushrods?
I知 THINKING of installing a set of the D5AE 351W heads on this 94 351W roller short block I have. I知 not too concerned about the compression ration unless I would be dropping it considerably?? What I am really worried about is the pushrod length & geometry, anyone know what is involved when going from pedestal mount to stud mount on one of these engines? Thanks , Crossy
Pushrods
Because the press in stud style heads were never combined with a roller lifter block on the 351, there was no stock length pushrod that was dedicated to that application.
You could get an adjustable pushrod and measure what you need, then probably find a commercially available pushrod by looking through a catalog that arranges them by length.
Or you could throw in the towel and get a good pair of GT40 or GT40p heads, or even the very common E7TE heads and use the stock pushrods for a 1994 351 with a roller camshaft.
The D5AE heads may not have hardened exhaust valve seats, which should be considered.
fordf350man
05-27-2015 11:46 PM
Redtires019
01-07-2009 09:18 AM
grabberblue
04-07-2007 10:18 AM
BaronVonAutomatc
15
03-04-2007 10:35 AM
