Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
333 FT Carb adjust
Old Oct 28, 2017 | 07:16 PM
scrapbmxrider16's Avatar
scrapbmxrider16
333 FT Carb adjust
anyone have any tips on adjusting the carb? I have the manual but it is kinda vague due to hang all the motors in there
Old Oct 28, 2017 | 07:20 PM
85e150's Avatar
85e150
330 carb adjusts the same as the others.
Idle screws about 1 1/4 turn out, adjust to the best idle, then in 1/4 turn. (iirc, long time since I fiddled with those)
Choke should open fully when warm. Float level, power valve etc should be replaced/adjusted with a rebuild.
Check for vacuum leaks before you do anything.
Best I can do.
lud04X
Jul 9, 2007 05:21 AM
fords_forlife
Sep 20, 2005 09:07 AM
1985ColumbusF150
Oct 23, 2004 02:00 PM
onestep
Jan 18, 2002 09:13 AM
baitboy
Apr 25, 2001 01:56 AM
