1978 - 1996 Big Bronco
95 no start
Old Oct 28, 2017 | 06:36 PM
Fordman96's Avatar
Fordman96
95 no start
'95 bronco. Turns over great.
new fuel pump. New plugs/wires/cap/rotor/coil pack.
Getting fuel all the way back to return. (Good fuel, purged system of everything)
Have spark. Tested it redneck style with a screwdriver over a ground.
Was told it ran.
Had it running by feeding fuel through the intake, but it will not run without doing that.
Swapped the dash from my 96' in there, but left the computer so that shouldn't be a factor. Tried unplugging the spout connector and starting it (nothing). The tac moves while cranking.
Don't understand why it won't run on it's own.
Any suggestions would be nice
Old Oct 28, 2017 | 08:28 PM
fe390pc's Avatar
fe390pc
Sounds like the injectors are not firing. Do you have a code reader? I would see if there is a change in the wiring from the 96 to the 95, or maybe just a ground issue.
Old Oct 29, 2017 | 08:18 AM
Fordman96's Avatar
Fordman96
Today we're going to change over the injectors and see what happens. Will update as it goes.
CoastyAV8R
May 5, 2018 08:58 PM
OneLostCowboy
19
Nov 13, 2016 02:50 PM
dizturbed
Dec 27, 2006 06:13 PM
farlem99
3.0L V6
Mar 7, 2006 07:21 PM
red
Dec 23, 1999 07:22 PM
