drivers power window switch
Oct 28, 2017 | 02:24 PM
im having trouble with switches going bad.several companies make a replacement switch.any of them last?
Oct 28, 2017 | 08:32 PM
Same here, got 2 bad ones that were only replaced 3 years ago.
Cheap Chinese knockoffs, can no longer find real FoMoCo. Green's are out of the real ones.
Oct 29, 2017 | 12:24 AM
Nov 1, 2017 | 10:53 AM
Drivers power window switch (91-97) E69Z 14529-B, over 400 available in the Memphis warehouse. List price is $37.78.
Nov 1, 2017 | 05:46 PM
Quote:
Originally Posted by
93nighthawk
memphis warehouse?do i order through ford?
Nov 2, 2017 | 11:45 AM
Any Ford dealer can order it and have it in 2-3 days.
Nov 3, 2017 | 04:41 PM
93nighthawk
do you know if the four sided black trim around the window regulator on the 86-91 is still available?
Nov 6, 2017 | 10:32 AM
zenish
If you are talking about the trim piece that goes around the switch, it is no longer available and I don't see any in the wild. E69Z 1223713-A
Nov 6, 2017 | 04:41 PM
just disconnect the switch's connector and clean the pins, they get oxydized and start to work intermittently.
I recently removed the dash gauges pod and cleaned-polished all the pins of all the gauges which were acting funny. Now they work perfectly.
Mish
1997 - 2003 F150
Feb 24, 2010 07:36 PM
utahtom
Jun 30, 2008 07:36 PM
gad4wd
2004 - 2008 F150
Feb 18, 2008 10:33 AM
