Sponsored by: Auxito
1997 F250 Light Duty Error Code
Old Oct 25, 2017 | 05:31 PM
megyed's Avatar
megyed
I live in a state the requires inspection on my vehicle, and it is throwing a PO401 Insufficient Flow code. I inspected the hoses and noticed that one of them was cracked, and replaced it. Also cleaned off the intake with fine sand paper to remove corrosion from where hoses were connected. Cleared the code and drove it for a couple hours and the code is back. Any ideas?
Thanks!
Old Oct 25, 2017 | 08:42 PM
Bluegrass 7's Avatar
Bluegrass 7
I have more than ideas.
You need to know the code refers the EGR system operation.
Not just any hose condition on the engine. That's why the specific code.
The computer does a flow test two times for each drive cycle.
The ports behind the EGR valve likely are plugged with carbon.
To check this, apply vacuum to the EGR hose port while the engine is at idle.
If the motor begins to idle rough and or stall, the ports are open and clear.
Then look to a faulty DPFE sensor that cannot report the flow reading pressure to the computer.
If no rough idle the ports are blocked. The EGR needs to come off to access the manifold ports for clearing.
Good luck.
2oo1 4x4
1997 - 2003 F150
May 15, 2014 08:05 PM
JHUBB58
1997 - 2003 F150
May 17, 2010 10:27 PM
gipson2105
1997 - 2003 F150
Jul 28, 2007 06:35 AM
pos2nat
May 11, 2007 11:01 AM
daw1264
1997 - 2003 F150
Feb 7, 2002 07:30 PM
