76 F150 Engine Swap
Old Oct 25, 2017 | 10:30 AM
Jacob Yoneda's Avatar
Jacob Yoneda
76 F150 Engine Swap
I have a 76 F150 Short Box that has L6 300 4x4 4 speed manual. I want to swap it out to a 408w Stroker that has 450hp and 500tq. I know that the bell housing and tranny will fit. I am wondering what driveline components do I need to upgrade to have it handle that much hp and tq?
Old Oct 25, 2017 | 04:49 PM
85e150's Avatar
85e150
Welcome to FTE.
What are you going to be doing with the truck?
That's a lot of motor.
Old Oct 25, 2017 | 06:27 PM
Jacob Yoneda
It has 35 inch tires with a 4 inch lift so it will be a street and mudding truck.
Old Oct 25, 2017 | 08:21 PM
85e150's Avatar
85e150
What gears are you running?
Old Oct 25, 2017 | 08:25 PM
Jacob Yoneda
It might be 3.50 because with my 300 I got a speeding ticket going 80 and rpms run about 2600 at80mph
Old Oct 25, 2017 | 10:50 PM
baddad457's Avatar
baddad457
The weak link I'd guess would be the transfer case, depending on what it is. The rear will be a 9", plenty strong for it as long as it's got 31 spline axles.
Old Oct 25, 2017 | 10:55 PM
richter roxs's Avatar
richter roxs
Put the motor in first then see what breaks then replace that part with a stronger unit .
But I wouldn’t worry about changing anything as this sounds more like a fantasy than reality.
Old Oct 26, 2017 | 08:23 AM
Jacob Yoneda
Baddad - Thanks I will take a look at the transfer case and check the spline.
Richter - It is not fantasy I am going to order a crate ford 408w motor but I will not just wait til something breaks.
Old Oct 26, 2017 | 10:16 AM
richter roxs
If that is the case then the first thing would be a brake upgrade , you are more than doubling your horse power and with larger tires your brakes will be boarder line at best and dangerous to others at worst . most cars on the road today have half your stopping distance.
I have been on many forums for many years and 95% of the people talking about building or buying stokers, turbos, supercharging and the like are just blowing smoke and wasting other peoples time .
that said good luck and post some pictures of your build , But I am not going to hold my breath. No offense .
Old Oct 26, 2017 | 10:22 AM
Jacob Yoneda
Yeah, well I will but it won't be for a year. I have to save little bit more money but it will be done. I understand that there are a lot of dreamers and not a lot of doers! I just need to get everything upgraded before I put more power into the truck so I don't die haha!
Old Oct 27, 2017 | 10:47 PM
baddad457's Avatar
baddad457
You're not going to die from not upgrading parts. You'll die from driving stupid. As for breaking parts, that's only going to happen from the sudden application of torque with too much traction at the ground.
JaniceDelp
Engine Swaps
Feb 24, 2017 07:33 PM
Morg89
15
Mar 9, 2013 07:02 PM
twistedlee
Engine Swaps
Oct 22, 2004 09:48 AM
bigredford04
Jul 10, 2002 06:58 PM
