What do I need to upgrade/replace next?
Everything that's been done so far:
EGR delete
Full bullet-proof
Custom SCT tunes from Warren Diesel
SCT tuner
Edge CTS2 moniter
155/30 injectors from Warren Diesel
High flow stand pipes from Warren Diesel
New OEM dummy plugs
Rebuilt (OEM) turbo
Stage 2 transmission solenoids
New glow plug harness
FICM rebuilt by FICMRepair
100 HP Power Hungry Performance tune on FICM
New batteries
Airaid intake
6.4 pushrods
Things I'm thinking of getting:
6.4 starter
Upgraded power/ground cables
Alternator (Leece Neville or DC?)
Turbo
Billet wheel
Intake manifold
Have the tint redone
Spray-in bedliner
Lift kit
Return style fuel line
Aftermarket exhaust
Snow plow (to try to make some money)
After reading this on the FICMREPAIR site, "The factory wiring harness was designed specifically for the stock alternator’s output. When a high output alternator is put into the equation, the stock wiring can't transfer the power that the new larger alternator creates." I think the alternator needs to come off the list as well
Complete Wiring Kit
https://www.dieselpowerproducts.com/...werstroke.aspx
6.4 starter
prevenative maintenance
safety for upgrades I already have
safety for the upgrades I already have/prevenative maintenance
Turbo
Razzi recommended for EGT issues after the other upgrades I’ve made
Billet wheel
cheap way to upgrade instead of turbo for same reason
Intake manifold
ok, you got me here. There is no reason for this one
considering the price this might be a nice touch on the truck. I should have mentioned the tint is VERY scratched/purple
Spray-in bedliner
there was a 5th wheel in the bed and is now gone (previous ow we kept it) plus there are several chips in it as it was a cheap job and getting the bed “resealed” will combat any rust from forming.
Lift kit
again, this is nothing the truck needs
was more than I was wanting to drop on the truck with all the other things I had to buy, but Ed recommended it
Aftermarket exhaust
was thinking it would help with the EGT and be good for all the rest of the upgrades
just something I’ve been planning since I bought the second Excursion
