is a 351C points style distributor a direct drop in for the 351M?
Well that works for a good enough reason. I do believe that if you want a direct swap-in distributor you have to go over to a 460 engine. Guessing there are still some points-type distributors around in the yards. Or for that matter, just new in a store is likely not that expensive.
Did you happen to have the Cleveland distributor handy? Or did you know where to snag one?
Paul
Paul
https://www.forbes.com/forbes/welcom.../www.bing.com/
Im keeping complicated electronics OUT of the vehicle I need around my farm, this is one of the reasons. Yes, Ive got spares.
All M-block (351M/400) distributors are mechanically interchangeable with all 351C engines and all 385-series (429/460) engines. However, much like carburetors, distributors are calibrated for a specific vehicle and engine application.
The police will be able to shut down a modern IGN Sys, which may be inconvenient during a chase. Also, when the Greys finally decide to land, they can do the same. An old points system will not be affected...
SOURCE- M-Block 351M/400 Parts Reference
Ive be watching the world become more and more dependent upon new technology, and when I was on active duty, they showed us some seriously spooky stuff from cars computers being hacked EASILY, remotely to driving habits and geo locs being tracked by the fedgov and ins companies on any OBD II and newer vehicle, to the cop-spike strip thing to the very real threat of EMP....it was at that time that I decided.....that LOW tech is the BEST tech.
The distributors are the same between the 351C and the 400/3551M block even though the deck height changed between the 351C and the 400 Blocks the distributor did not.
As seen in the below pic of a 351C and 400 block the installed height of the distributor did not change.
Furthermore if you click on the item number for the A-1 CARDONE 302893 Reman distributor for the 351M at the below link you will see it back dates to 74 in the applications when the Cleveland was still in production plus it carries D4 Ford Pt number.
1975 FORD LTD 5.8L 351cid V8 Distributor | RockAuto
Matthew,
after reading this post, and looking at your link, I got to thinking, my distributor vacuum advance is rusty, and I'm not sure it works correctly, so maybe I should just get a new distributor, as the prices are very reasonable.
I noticed your link is for an LTD, so I went to my 1979 F150 5.8L, and looked at them, which are mostly the same ones, but now here's my question,
how do I know, or tell if mine is a single or dual vacuum, or has a governor or not ?
Matthew,
First is a dual diaphragm
Second is a single diaphragm
The governor I believe the are referring to would be fitted to the carb.
So I do not think they are meaning the distributor has a governor like the old VW distributors that just shorted out at a given RPM. I have never seen an Autolite/Motorcraft distributor with an internal governor.
I don't think Ford ever used them. I won't say for sure that Ford never used them as with Ford anything is possible lol.
Beware, while the rebuilt distributors themselves may be good - and it is the heart of your engine after all, all of the rebuilders seem to ship with el-cheapo points and condenser. Only use quality NOS or NORS ignition components. Autolite, Echlin, Standard Ignition. If using points they both have to be top quality.
IMO
And, as mentioned, they are not using FORD/MOTORCRAFT parts but whatever the CHI-COM deal of the day is, and it's gonna cost you.
I believe new MOTORCRAFT IGN parts are still available.
V8 Points (1957/ ) B8Q 12171-A - Condenser C9AZ 12300-A - Breaker Plate Asm D2PZ 12151-A.
The above are from memory as I no longer have my MPC. Bill and/or JEFFAFA will have to confirm the PN's and availability. They also have MOTORCRAFT short numbers so price shop online.
Some speed shops still have a distributor machine that can allow them to set any curve you need or want.
