'69 Longbed...the work continues...
My engine is in REALLY good shape. There are no leaks of any kind and the engine got a new timing chain and cover, water pump, and fuel pump just last November. The electronic ignition has really made it start-up on the first try and the new dual-exhaust sounds sweet. It's not a performance vehicle (yet) but I have a great base upon which to build. FiTech EFI and an Edlebrock 4-bbl intake are on the horizon now.
In the update column I removed the last vestiges of the aftermarket A/C system that died a long time ago. Removed the old, broken condenser that sat in front of the radiator and the idler pulley and bracket for the old compressor. The engine bay looks considerably better without the old, non functioning pulley and bracket in the way.
The next improvement will be engine/trans mounts and new rear shocks. I will also be taking a grinder to some small areas of the frame and putting some paint/primer down. The only way to beat rust is to stay ahead of it. Oh, and the air cleaner cover is in sad shape. A little Ford Blue paint should clean that up nicely.
