What motor do I have?
Looks like a 460 to me, but I'm not that well versed in them to be 100% sure.
Looks too like there were some nice upgrades. Valve covers, A/C compressor, SuperCooling radiator, 3G internally regulated (and high output) alternator.
Very nice.
What is your truck? 2 or 4 wheel drive? Standard cab or otherwise? Presumably the '78 in your username?
Hopefully someone will know for sure what you have.
Paul
Very nice.
Paul
At first glance I wanted to say 460, but that's just going off the shape of the valve covers. Looking closer I want to say 335 series, 351M/400, something about the water neck. Granted, it does have aftermarket parts, but I don't see the little two inch or so coolant hose between the top of the water pump and intake that my 460 has and my 351M doesn't.
I am rolling dice and say 460 with a alternator relocate (high mount) kit.
351C/M/400 335 series: 8 bolts in rectangular valve covers. Timing chain housing is part of block. Thermostat housing on block. Exhaust bolt holes diagonal.
351M/400 335 series: intake is 12.7" wide the 351C is narrow. The 351M and 400 are identical externally, only internal parts examination can tell them apart.
351W/302/5.0L 6 bolts on trapezoidal valve covers. Thermostat housing on intake. Exhaust bolt holes horizontal.
429/460 385 series: 7 bolts in rectangular valve cover
352/360/390/427/428 FE series: Intake goes under valve covers.
It looks as thought the thermostat housing fastens to the block and not the intake manifold. I am leaning to a 335 series engine. Is there 8 bolts fastening the valve cover to the heads?
as 77&79F250 states:
