Vanity Mirrors Harness
I found a complete NOS harness from a 94 Lincoln that would appear to have everything I would need. https://www.ebay.com/itm/NOS-OEM-For...ZZARpi&vxp=mtr Would this harness be plug and play? It looks like a complete lighting harness, that I would need to pull the parts I need out to graft into my existing harness. Also figure I might need to lengthen some of the wires.
Your thoughts are appreciated.
I know it is way more than I need, and I didn't intend to use the whole harness. It appears to have what I am after and it isn't hacked up. It also had the rear view mirror wire trim which seemed like a potential bonus if I wanted to source an auto dim mirror.
Was the lighting package harness just a plug in extra? I have yet to see one whole, I have only seen the accessory end of the harness and not the power source end.
From what I have found it snaked up the driver side A pillar and over the windshield.
I can still get my hands on the the plug connectors, and build the harness myself which would probably be the most cost effective way to go if I can sort out where to add it to the existing harness.
I would go to the JY but there are none worth visiting nearby.
Unless you find the lighted visors, then the harness is mute point.
I have a gray setup minus the rearview mirror(broke when removing) I would be willing to part with
