Sponsored by: Kumho
Leaf Spring Replacement
Old Sep 10, 2003 | 10:07 AM
Doityourselfer's Avatar
Doityourselfer
Is it required to leave the tire on when removing the rear leaf springs? This is my first time doing so, and the book is not specific.
Old Sep 12, 2003 | 06:18 PM
btg's Avatar
btg
Here's how I did it on my leaf spring F350 2 months ago. I was supprised at how easy the job went (with a pneumatic impact wrench.)
Take the tire off.
Support the truck on jack stands and put a jack under the axle.
Disconnect sway bar links, shocks, and panhard rod as applicable.
Remove the axle u-bolts.
Lower the axle. BE CAREFUL NOT TO DAMAGE THE BRAKE HOSES!
Remove the shackle bolts. You might have to cut these.
Remove the springs.
Old Sep 13, 2003 | 12:08 AM
02superstroker's Avatar
02superstroker
you'll probably have more trouble if you leave the tire on.. you will have to lift the truck that much higher. not very safe. Also when you are supporting the axle on the jack.. try to use 2.. one on each end. Helps a lot, you dont have to try to balance it.
Old Sep 13, 2003 | 07:41 AM
Doityourselfer
Thumbs up Leaf Spring Replacement
Thanks to all for the sound advice. Spring replacement went well.
It's not something I'd want to do again any time soon, but the knowledge I've gained will make it easier next time.
StrokinIT2001
Apr 5, 2017 10:34 PM
jniolon
Apr 3, 2017 04:33 PM
Satch
1997 - 2003 F150
Jan 29, 2016 07:23 AM
willieyp
Oct 1, 2015 09:51 PM
twinpeaks
May 30, 2012 06:01 PM
