Here is a little hypothetical situation for you...
Let's say that someone bought a 69 F100 on Ebay (it should be in my gallery), and now has to fly out and drive it home.
Let's also say that the trip just a little over 1000 miles.
Now let's assume that the truck has no radio.
The trip in question will occur 6 days from today.
The person in question could take a portable CD player, but what he really wants is to be able to listen to the different radio stations along the way.
A portable radio might do the trick, but he is concerned that the reception will suffer, not to mention the issue of power to the radio (batteries or run a power converter off the lighter).
An MP3 player is not an option, as this guy is not jiggy with the current technology (or terminology).
The budget will allow small purchases - let's say less than $75.
Does anyone have a suggestion? Barry, anyone who knows about half wave lengths ought to be a real wiz at this....
Hi, this may be low tech but for your budget and purpose I would just buy a boombox with a tuner in it, they are pretty sensitive plus you could play CD's. When you get home the purchase will still be useful. A Walkman would do it but you'd get busted for wearing the headphones while driving.
I like a radio from about the 1986 era. You can get these for about $25 in a wrecking yard. AM/FM, some have a tape. The wires aren't too hard to figure out. Hook up temporary speakers and power and you will be set.
I like the small boom-box idea. They usually have good reception. get one with a 12v adapter if possible. Battery's are expensive these days.
I've done this twice now. Ebay and roadtrips. I love it. Just in case you have not seen my story's, follow the links to the trips to pick up the trucks just below the picture of my 67:
If you do a search here, you might find my old thread about what to take when flying out and driving a 30+ year old truck 1000+ miles. I think it was in march or april of this year.
I have followed your road trip exploits with much interest, and the truck will have an oil change, and belts / hosed checked and/or replaced before I depart. It has also had a recent PA inspection, which the seller says is fairly rigorous - Anybody in PA care to comment on that?
pa'struck - the truck in question is in Reading PA. I will be bringing it back to central Iowa. At least I won't be driving through the desert, like Gtex has done. I will have the advantage of driving through some of the most populated states (PA, Ohio, Illinois). I should be on the road about 4:00 pm Tuesday, so I should be able to put 7 or 8 good hours of travel in during the cool of the evening, before I stop to rest and if there are no problems, I will finish the trip on Wednesday.
I too, am a little nervous about the trip, but the 360 only has 85000 miles on it, give or take. I know that engines can break from lack of use as well as too much, but it has been inspected and of course, the seller claims it (altogether now)
The F100 I purchased was driven from New Mexico to western Pennsylvania about 5 months ago and made it with no problems... It's a 97K mi, mostly original truck. I currently have no radio so I can understand, long trips get boring....
Why not purchase a cheap ****/shaft style radio and zip tye it somewhere under the dash... Theyre simple to install, 1 positive wire, two speaker wires and everything is a common ground... Run to a pair of speakers in boxes on the floor.
The boombox should be ok for strong signals, but may be a bit iffy if you are out on the interstate. Mainly cuz the antenna is inside the truck surrounded by a metal faraday shield. You would be much better of if you could find an old car radio to rig up, and install a real antenna outside. The antenna will be handy in the future no matter what radio you have. I have an old ac-delco AM-FM on my floor. "70-80's pushbutton type". It won't fit in the ford radio hole. I know running a GM radio in a ford truck is funky, but the older ac-delco is one of the best car radios ever made. Very good for AM. BTW, a 1/2 wave for 88 mhz is 63.682 inches. But you would usually use a 1/4 wave if mounted on a truck body. 30-35 inches is a good height for FM. But less will do. The taller the better for AM. MK
