Pull the valves or run it as is?
351m
Back story:
I removed the intake manifold to change the gasket. I noticed a lot of coking on the heads so pulled them to clean them up. I also am replacing a couple valve lifters.
I removed the heads, turned them upside down and filled them with liquid and left to get parts. I came back and they were still full, no leaks.
I was not blowing blue smoke or anything, should I just clean em up and run them? Or remove them all and clean the carbon off the stems.
I have to have this back together tomorrow.
Back story:
I did that with a '72 and 390, lol.
But, I figured you guys would not comp me a break and tell me to pull the valves, so one head is apart. I am glad I did because now I know the seals will be new.
I am using a $12.99 spring compressor from Harbor Freight. Not the best $12.99 that I have spent.
Jklnhyd,
I'm certain YOU will feel better about getting the heads cleaned up! If you've got the ability to do it, then why not since you're that far into it? You may notice a little performance increase, but you will almost certainly gain some longevity out of it.
For what it's worth - the pneumatic valve spring compressors are the bomb, and the giant C-clamp type are good, but every other type of valve spring compressor I've tried is junk.
