Ecm questions
Old Oct 14, 2017 | 02:18 PM
zgray18's Avatar
zgray18
Ecm questions
Pulled the ecm out of my 1995 Bronco 5.0 E4OD. The box was painted black with some stickers on it leading me to believe it’s been replaced. The inside doesn’t seem bad but I’m gunna replace it because I’m thinking that it’s giving me issues. Could anyone tell me what number I should look for when buying, F4TF 12a650 Aaa or a F5TF 12a650 Jb?
Old Oct 16, 2017 | 07:53 AM
rla2005's Avatar
rla2005
F4TF-AAA (HOG0) is a 1994 PCM. F5TF-JB (WAY1) is for a 1995. They are basically the same. Given the symptoms on your other thread I would not suggest trying to replace it just yet. Answer a few questions, then we can help determine which way to go.
I always suspect replacement PCMs, but no sense spending your money for no reason. On the other hand since the PCM is out, open it up and inspect for signs of leaking capacitors. Very common issue.
GoldCo
16
Oct 12, 2018 09:21 PM
GoldCo
Oct 2, 2018 11:26 PM
ZJRICK
Jul 15, 2013 08:04 AM
mojo79
Jun 9, 2012 12:39 PM
budperm
Jul 29, 2007 02:12 PM
