Sweet Spot
Old Oct 14, 2017 | 09:05 AM
MacMan48's Avatar
MacMan48
Question Sweet Spot
Hi,
I'm new to the PSD and have some questions.
I have a lot of miles with diesel trucks, 14L to 5.9L and they all have a RPM sweet spot where they are the "happiest".
Where are the 2017 6.7L PSD's the "happiest" in the RPM range?
TIA
Old Oct 14, 2017 | 09:38 AM
HRTKD's Avatar
HRTKD
1800 RPM is max torque. There is a thread in the 2017+ subforum where a member calculated out RPM for each gear ratio. I think this is the thread: https://www.ford-trucks.com/forums/1...at-70-mph.html. See post #10.
Old Oct 14, 2017 | 09:53 AM
MacMan48's Avatar
MacMan48
Thanks for the reply. I'll go check it out now.
This is me:4.10 axle is turning 2051 RPM according to the math on that thread. Does the PSD like to run at max torque consistently? I've been dropped on my head several times so mafs is hard for me.
Old Oct 14, 2017 | 12:48 PM
Painted Horse's Avatar
Painted Horse
Computer seems to find the right gear for me. With over 150,000 miles on my 2011 truck and 80,000 miles on my current 2015, I can't tell you that I've found an rpm that my truck hated.
I'm not sure what sweet spot you are looking for. Are you looking for best fuel mileage or best coolant/oil temps? These engines seem to lug along at 1500 -1600 rpm on interstate roads with almost no effort.
Old Oct 14, 2017 | 01:54 PM
MacMan48's Avatar
MacMan48
I am looking for the spot that satisfies the most parameters you mentioned. Everyone wants the fuel milage but road and atmospheric conditions play a role in fuel economy that are out of our control. What you are hauling or towing obviously impacts fuel economy. My understanding is the driver is responsible for about 35% of fuel economy. For that reason I use the cruise as much as I possibly can.
I totally agree with you. I have not found any road conditions that cause any effort for this motor at all loaded or empty.
It's good to know that there is no particular rpm to avoid/that is hated.
Old Oct 14, 2017 | 02:55 PM
Just Strokin's Avatar
Just Strokin
I don't look at rpm but the mph I seem to have the best all around performance is 62-65mph. I have 3.73 gears, so this puts it around 1800 rpm. Also, the tires on my travel trailer are only rated at 65mph as safe.
Bee surprised how many times the same people will pass you on a long haul multiple times when you are loping along at 62-65mph.
Old Oct 14, 2017 | 03:52 PM
MacMan48's Avatar
MacMan48
1800 ok. That's peak torque. Are you on 17's or what?
I used to subscribe to the gear fast run slow theory and it worked very well for me but even with the 4.10's on 17's below 65 "feels" like I'm lugging it a bit.
Running 70 on the flat without much wind I was seeing 12.9 with a TC and about 2050 to 2075 RPM but that's just looking at the dash tach. I didn't pull out the torque program and get a digital read on the rpm.
No, I wouldn't be surprised at all. Steady and smooth equals fast. Hammering on it from rest stop to fuel stop to food stop makes exactly no time.
Good on ya for keeping the speed down on those trailer tires. Too fast is too dangerous and you can end up peeling part of the trailer side off if it's not a flat bed.
Old Oct 14, 2017 | 05:50 PM
senix's Avatar
senix
mine is 2013 DRW with 3.73's. 65 mph is right at 1800 rpms and it runs there all day long.
Old Oct 14, 2017 | 06:08 PM
Painted Horse
Mine have been SRW with 3.55 rear ends and they seem to run just fine in the 1600-1800 rpm range. Climbing mountains or during exhaust braking I'll see rpms in the high 2000's But most driving, with or with out a trailer is 1600-1800
Old Oct 14, 2017 | 07:02 PM
Just Strokin
Yes, running the stock 17's.
Old Oct 14, 2017 | 10:10 PM
MacMan48's Avatar
MacMan48
Ok that helps. Thank you all for your input. Sounds like 1700 to 1800 rpm is the sweet spot.
Thanks again.
Anything else I should know about these PSD's? Other than good fuel and LOF?
Old Oct 15, 2017 | 11:53 AM
camminich's Avatar
camminich
That 1600pm range does indeed appear to be the happy place. I have the taller 3.31 gears (18" rims) and I find I am always right someplace in between 1600 to 1750. It's a good cruise pace with our without the trailer. Even with hills there is no gear hunt, usually not until it become a 3% or more grade.
Old Oct 15, 2017 | 08:01 PM
MacMan48's Avatar
MacMan48
Thanks. 3.73 are great gears.
Great to know. Are you running in tow/haul when you see the higher rpms? I assume yes but it's best to ask.
I don't have anything like the miles you do on my truck but this is really good information. You're pretty long legg'ed with 3.31's. How fast are you running at 1750?
I haven't seen the truck hunt for gears yet. Haven't had it break a sweat loaded or empty.
Old Oct 16, 2017 | 06:41 AM
Gearitis's Avatar
Gearitis
I think I can relate to what you are calling the "sweet spot". Pulling our 12k fiver, it is right at that 65 mph in T/H which is right at 1650 RPM, 70mph is ok at 1775 rpm. Empty, that 70-75 Mph is great and also pretty easy driving. And the RPMs are the same empty as pulling so really not much difference as you barely know you have anything behind you when pulling anyway.
Old Oct 16, 2017 | 07:19 AM
U235Fishin''s Avatar
U235Fishin'
A ditto with me .....
