speedometer cable adapter??
Old Oct 14, 2017 | 06:40 AM
beest's Avatar
beest
Question speedometer cable adapter??
Hello I am not sure if there might be a answer here but here goes. I have a 1988 class a motor coach on a john deere chassi with a ford power plant . The speedometer broke so I replaced it, I put 170 miles on the speedo and it stopped working again. I took it out again to find the speedo extension cable failed do to the bend so I had too replace that. I was able to find a new cable but routing the cable it has to much of a bend. Anyone know if there is a adapter available to make a 90 degree angle that will work? I have searched the web and found some but most of them are reverse direction. Do I need a reverse direction ? I also found one for corvettes for tight areas but putting a chevy product in to a ford will this work. This is very confusing
coppertales
Oct 6, 2015 10:49 AM
RadioControlGuy85
Dec 12, 2012 04:55 PM
midsouth
Oct 8, 2011 12:33 PM
72sportcustom3906.4l
Jun 20, 2009 05:56 AM
jowilker
Jan 4, 2001 03:05 PM
