It lists kits for 57-64 and doesn't note between fitting 2 or 4 wheel drive. Were the 2x and 4x trucks similar enough in that era that these kits would work on both? I'm also wondering if my 65 F100 4x with the older leaf spring front suspension is much different than the 57-64 trucks mentioned. Assuming these kits do work on 4x trucks that is.
1961/64 F100/250 2WD & F350 and 1961/64 F100/250 4WD are similar.
1965 F100/250 4WD; 1965/66 F350; 1966 F250 4WD are similar to 1959/64 4WD, but some of the parts are not the same.
