Truck box interchange
Old Oct 12, 2017 | 02:38 PM
Matt 8787's Avatar
Matt 8787
I have a 1997 Ford F250 heavy duty. It is the old body style. It is a long box with dual tanks and I am wondering what previous years are interchangeable with this particular year? I found a truck bed off of a 92 F150 but I'm not sure if it's compatible. Also if somebody could point me in the right direction so I can find the part number for my truck bed or a parts diagram with the part number that would be great. Thanks
Old Oct 12, 2017 | 03:27 PM
tjc transport's Avatar
tjc transport
i ain't rite
any bed from 1987 to 1996 F150, F250, F350, and 97 F250 HD or 97 F350 will bolt rite on to your frame.
Old Oct 12, 2017 | 07:55 PM
mrollings53's Avatar
mrollings53
You can go all the way back to 1980 if you don't care about body lines matching.
Old Oct 13, 2017 | 12:24 PM
Matt 8787's Avatar
Matt 8787
Body lines
Do you have any idea if the Body Lines will match up? I was told at one time that there was something slightly different with the 97 F-250 HD. I am not sure if that is actually the case though. Thank you
Old Oct 13, 2017 | 01:43 PM
Brain's 97 Diesel's Avatar
Brain's 97 Diesel
1980-86 had different wheel house body lines than 1987-96 (& 97 F250HD-F350). Super Dutys don't fit and neither do the 1997 F150-250s.
Old Oct 13, 2017 | 01:59 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Stylesides:
1980/82 tailgate is 1980/82 only. Has the latches made as part of the tailgate supports (scissors).
1983/86 tailgate is different than 1980/82 and 1987 and later.
Old Oct 13, 2017 | 03:01 PM
madpogue's Avatar
madpogue
To answer your questions, there's nothing "different" about the 1997 F250 HD; the 1992 bed you're looking at will bolt right down and the body lines will match. The only factor is the fuel filler(s); if it's a dual-tank bed, you're golden.
What makes 1997 "different" as a model year in general is that the F150 went to a new body style in 1997. And they introduced a "Light Duty" F250, based on that F150 style. (It really should have been called an F200.) The F250 HD (as you know) and F350 retained the old body style. This admixture of models / generations means loads of hijinx, fun and confusion among the mouse-pushing "uhh, year make and model?" flunkies at the FLAPS. It was all so fabulously confusing that Ford didn't even issue a 1998 model F250 HD or F350. They just waited and introduced the whole new SuperDuty generation of F250, F350, etc. as 1999 trucks.
Asim Khan
Feb 2, 2016 01:19 PM
Pushpin
Aug 6, 2015 09:19 AM
Simple Ben
Nov 14, 2014 02:22 AM
Dodge/Cummins
Nov 28, 2008 02:17 PM
cashmoline
Mar 13, 2005 07:05 PM
