Speedometer Calibration
Old Oct 12, 2017 | 02:03 PM
2017-350's Avatar
2017-350
Are there any programmers that offer a calibration for 37" tires? I was interested in the EZ Lynk, but they don't offer that option.
Old Oct 12, 2017 | 05:55 PM
mhoefer's Avatar
mhoefer
Can Forscan enter revolutions per Mile to correct? Check the forescan thread, might be a solution. Alternative would be to have the Ford Tech work in the IDS to correct. Lots are doing this as they are adding lifts and tires at dealers so they have to be able to correct.... then you can verify with a GPS application measuring speed compared to speedo.
Old Oct 13, 2017 | 07:43 AM
RugbyRef's Avatar
RugbyRef
Yes. I have the Hypertech installed in my truck after I put on 37's. Took all of five minutes to install it.
Tim
Old Oct 13, 2017 | 10:37 AM
Shreve T's Avatar
Shreve T
Tim
I've heard that you have to take the dash clsuter out in order to put the Hyoertech inline with the speedo ? If not then where did you plug it into ?
Old Oct 13, 2017 | 12:52 PM
RugbyRef's Avatar
RugbyRef
Yep...I did have to remove the dash instrument cluster, but it is a very simple process. It plugs in behind the instrument cluster. I, then, just used two-sided tape (comes with the programmer) and set it out of the way. Buttoned it all back up and works like a champ!
Old Oct 15, 2017 | 12:04 PM
2017-350's Avatar
2017-350
Do you have a part number and where did you buy it?
thanks
Old Oct 16, 2017 | 08:49 AM
RugbyRef's Avatar
RugbyRef
thanks
Speedometer Calibrators Inline - Part #730125
Bought it directly from Hypertech for $229.
They might have it on Amazon or elsewhere, but I wanted to get it from the manufacturer.
Tim
Old Oct 16, 2017 | 10:40 AM
FmaxTurboSi's Avatar
FmaxTurboSi
ez lynk does have tire size calibration.....I just don't know if it goes up to 37"
Last I heard was that they were trying to figure out how to go larger than 34.5"
But they might have it finished by now. Might want to double check.
metru
Nov 8, 2017 09:26 PM
Ltngdrvr
6.7L Power Stroke Diesel
34
Apr 25, 2014 12:03 AM
acom01
May 18, 2010 07:06 AM
Dave Irby
2004 - 2008 F150
Feb 24, 2006 03:42 PM
nitropolaris2
1997 - 2003 F150
Nov 2, 2004 11:40 PM
