Smoke and 1 plug fouling
I had my engine rebuilt little over a year ago got roughly 5000 miles on it and Have been noticing smoke,oil smoke Blue from drivers side exhaust. when I got home I started pulling plugs and looking at them. The 1st one looked Great! Like a new plug still. The second on OILY and CARBON! all the rest of them looked Great. I am assuming that the valve Guide seals have gone south. The engine still runs great cept fer that one plug that gets oily and carbon ed up. The engine is a 390 mostly stock. What would you fellers think?
well was do-in some more checking and the oil was actually on the outside of the spark plug as I had a Valve cover leak last week was loose bolts. The end of the plug was carboned up like oil carbon so I think it may be valve seals. When I first start it cold and untill the oil gets warmed up It don't smoke. Just when the oil is warmed up
Could be
Well that is very common, specially if it had the old umbrella seals on it, replacing them means pulling valve springs, which can be done with heads on and heads off.... heads on naturally is the preffered method and requires the air hose adapter and shop air to keep valve from dropping while your working on it.... also if any head work has ever been done on your truck finding the correct valve stem seal size can be some serious detective work.... and you want the new rubber type with spring that dosent require milling on the head...
The new seal can be slightly shorter but must be dam perfect for circumference.... heres where i ended up finding a good match for my FE heads.... use a micrometer to measure the seals you take off as a starting point to get a good match...
https://www.alexsparts.com/
pic
Heres a pic of some different styles of seals, your truck came with the basic umbrella
I ended up using the Flex body and they fit snug and I have had zero leaks with them..... Of coarse it took me forever to match up the size, they were shorter than the umbrellas but nice and tight around the valve stem..... Good Luck !
I really doubt you have 1 cyl with bad valve seals. Years ago I fought the same thing for a while till I figured out the intake gasket was bad for whatever reason on 1 cyl.
Usually you'll see valve seals causing smoke when you go down a hill coasting not so much on startup. I know I changed seals and it wasn't any better. I ran on it on a hill leaning each way till it smoked like crazy. If you're guides are good there really is nothing wrong with old style umbrella seals, obviously the newer style is better.
Heck some of our old tractors don't even have valve seals. Not saying it's right but that's the way it was back then and they don't spew smoke.
The oil is more viscous when cold, and on some engines it takes a while for the oil to make its way to the rockers. (I'm not sure about the 390.) As mentioned already, you may be able to learn something by just inspecting the valve stem seals without removing the heads. But it also wouldn't be a bad idea to do a comprehensive compression test of the engine if it hasn't been done recently. You could save the results for future comparisons. If there is a ring or piston problem it will likely show up in the test.
If it's chattering, be sure to get your flywheel resurfaced.
Mine would chatter in reverse, and then a few weeks ago while working on something else on the truck, I noticed two missing bell-housing bolts! Then I checked the remaining ones, and one was loose and the others weren't very tight. So I checked the transmission bolts, and they weren't very tight either. I replaced the missing bolts and tightened everything down, and that got rid of the chatter.
Well I told the guy do-in it to PUT A NEW CLUTCH IN REGARDLESS! But he refused to do so. I don't get it myself! I am a bit pissed at that guy but nothing I can do now! Just have a clutch done now! Learn from mistakes, won't go to that fella no more!
