The camera has a mind of its own. It works in the mornings, most afternoons it doesn't. The warning comes on occasionally that states, camera not working find dealer.
Anyone know where to start looking. The truck is still under warranty, but with a intermittent problem just not wanting the hassle.
It acts like it might be a grounding issue. There have been times that re closing the tailgate fixes the problem. But it's getting more problematic.
I had the same problem on my 14. First step was to check all the camera connections and make sure they were tight and clean. If that doesn't solve the problem it is either the camera or the module in the dash. They replaced my camera and then ended up replacing the module. Have not had a problem since. My2cents.
