Oil Analysis?... Really Neccessary??
Old Sep 10, 2003 | 12:15 AM
Mykro's Avatar
Mykro
Could someone fill me in on doing an oil analyisis on my PSD... How its done?.. Do I really need it done?.. Why is it needed?.. Can I do it myself? ...Where to have it done?. Etc...
Thanks
Old Sep 10, 2003 | 05:29 AM
Quadzilla's Avatar
Quadzilla
The main purpose of an oil analysis is to determine what trace minerals are in your oil. The analysis will determine whether you have too much of a given element, for example copper. If so, that would be a sign that an internal part of the engine is wearing faster than normal, which would give you early warning of a possible future failure. There is an entire list of elements they check for, and they know what parts are composed of what elements, so the report might indicate that a high level of copper is a sign of premature main bearing wear. (I'm using this as an example, the main bearings might not even have copper in them.)
I have one done periodically, but certainly not every oil change. Once a year is typical for me, to see if there's a trend.
The best place I know to have it done is at Blackstone Labs. Click here for a link.
Old Sep 10, 2003 | 08:33 AM
theologian's Avatar
theologian
What QZ said..
Theo
Old Sep 12, 2003 | 06:35 PM
thinksnow's Avatar
thinksnow
Thumbs up Oil Analysis?... Really Neccessary??
You can go with the Amsoil full synthetic with a bypass filter system. You change the filters at scheduled intervals. They offer oil analysis at there labs. Keep changing your filters do the oil analysis and you could go 100,000 or better on one oil change. Most people are uncomfortable doing that but the oil is capable of it.
Old Sep 12, 2003 | 09:20 PM
Mykro's Avatar
Mykro
I have just ordered today, 3 bypass TP filters from Frantz
www.wefilterit.com
One each for the Engine, Trans, Fuel, And in the near future one for the coolant.. Its thee only way to go!!!
