F-250 sd, 7.3 diesel GUAGES (wiring)
Any wire that's hot with the headlight switch will work. I ran a tap down the pillar from the left most cab marker light. Lots of folks just use the spare wire from the brake controller harness pigtail.
Neither of those will allow you to dim the lights, but my insturment cluster lights are always all the way up anyways.
I have a 2002 7.3 and recently installed gauges. I popped the headlight module out and metered the dimmer portion of the module and found the blue wire with the red stripe that was the dimmer for the stock gauges.
I "T" tapped the wire and terminated the Auotmeter positive leads for the bulb lights to that wire.
Works fine.
Helps to have a meter, wiring color codes may be different for different years.
Use a bent paper clip to insert into the connector when probing for the correct wire.
Works fine.
Pop the big fuse panel cover off and under the dash to the right of the steering wheel there is a 6 wire connector, possibly an 8 wire but only 6 are used. Regardless of wire color, the top center wire of this connector is controlled by the dimmer. A voltmeter will confirm this. It's easy to access, and easy to tap. I assume that you already installed the gauges, but if not it's also easier to daisy chain all the light wiring so that you only have 2 to deal with when tapping in to the vehicle wiring. Hope I'm not too late to help!
