Cartouche Seat Kit
PS
also, the lebaron video above shows the burlap going on underneath the gray matting material before the cotton padding ... but the instructions with the cartouche kit make no mention of the burlap, and there was only one piece included which was scribed "seat back", which makes me think it is intended for the back of the seat back.
or, should i cut it (roughly) in half and use it under the matting (for both cushion and back) like in the video?
Here are a few more pictures;
1) Burlap first
Next, the grey padding
Trimming the cotton batting
Ready for cover stretch
Starting at the bottom of the back
Cover pulled over ready for final stretching and "hog rings"
I'm a bit confused about which frame you are referring.
While not necessary to be removed, the base frame that mounts the seat spring frame to the floor can make for more clumsy assembly of the upholstery if attached to the spring frame. Both can remain together if separation is an issue. Was this your concern?
On the burlap, my practice has been to lay it down first over the springs and hog ring it to the frame. I've needed to buy a few yards from a fabric store to do this. This is my preference and not a gotta. It does match the video procedure.
clearly i'm making this harder than it needs to be
thanks for additional info... hoping to tackle this tomorrow.
since the backrest back is open, was thinking of having burlap cover it (even if it isn't seen). wondering if i can just do an up and over-the-top with the burlap or if it would be better to just have 2 pieces, front and back. (though looking at seatback i'm not sure where to hog ring in the front since there is a flat piece of metal (approx 1") that runs along the bottom.)
or: do i start hog rings on the bottom of the backside, run forward and "between", up and over the front, back down the back and hog ring again to same spot so the whole thing is covered?
also, what do you do with the black cords at the bottom?
hoping it all makes more sense tomorrow when i'm actually doing it.
Mock up your material layers and attach points, including the final cover. Move around the pieces/layers until you're satisfied. There are multiple workable solutions. Find yours before installing the hog rings. Be critical of your work and adjust as needed. Enjoy the journey. This is usually one of the 'final push' items. Mught want to start planning the first drive route.
i think this is what is confusing me... i thought that that black portion would've gone on the bottom of the backrest (sandwiched on top of seat bottom when installed) but your photo shows it up and around the backside along the bottom.
well, looks like yours worked out just fine, so i guess i'll just copy what you've done there... looks like what, maybe 3-4" above the bottom of the back where you hog-ringed the black strip?
also, did you use all of the layers included of the cotton for the seat back?
thanks.
thanks.
thanks.
thanks.
#30
I've been thinking about buying the Cartouche kit from Mac's based on the good results discussed here. However, when I looked at the description in the catalog it didn't mention anything about the burlap or batting. I call them and the operator confirmed that all they're currently selling is the seat cover and the hardware to attach it. Did the kit you guys used include the burlap, gray padding and cotton batting or did you buy those things locally?
