Cartouche Seat Kit - Ford Truck Enthusiasts Forums
Cartouche Seat Kit
Old 10-11-2017, 11:30 AM
Cougar54
Cougar54 is offline
Cougar54 has a good reputation on FTE.Cougar54 has a good reputation on FTE.
Cartouche Seat Kit
I just started the reupholster of my 1950 F1 bench seat using a Cartouche kit from MAC's. The kit only supplies the burlap layer for the seat back and not for the seat bottom. Is this the way the original seats were? My original seat material was completely gone so I have nothing to look at for reference. Any insight would be appreciated.
Old 10-11-2017, 06:57 PM
Gertie-The '49 F2's Avatar
Gertie-The '49 F2
Gertie-The '49 F2 is offline
Gertie-The '49 F2 has a very good reputation on FTE.Gertie-The '49 F2 has a very good reputation on FTE.Gertie-The '49 F2 has a very good reputation on FTE.
Doug, I just took a gander at the seat in Gertie, which is original, albeit pretty seedy. Indeed, there is burlap both in the seat bottom, and back. Call them and tell them you want the burlap for the bottom too.
Old 10-11-2017, 07:14 PM
bhalemail
bhalemail is offline
bhalemail has a good reputation on FTE.bhalemail has a good reputation on FTE.
They sent enough for both the back and the bottom for my 50. Actually i could double lap it on both. Sounds like an honest mistake, they'll send you some
Old 10-11-2017, 07:33 PM
Gertie-The '49 F2
And I'll tell you, when that burlap hits the 68 year old mark, it literally generates a cloud of small fibers in the air whenever you plop your **** down on the seat. Got to where I use a blow gun and compressed air instead of a whisk broom to sweep out the old truck.
One of these days, I intend to re-upholster that seat. I am going to have to of course, my sinuses can't take much more.
Old 10-11-2017, 10:16 PM
Cougar54
Cougar54 is offline
OK guys, thanks for the info!!
Old 10-12-2017, 10:03 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is online now
bjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant future
I was reading somewhere that using canvas instead of burlap on top of the springs provides better support and distributes weight more evenly over your springs. Instead of hog ringing the canvas they hand sewed the canvas to the seat frame.
Old 10-12-2017, 10:51 AM
49f3dls's Avatar
49f3dls
49f3dls is online now
49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of
On my DYI I used canvas hand sewn on the springs and burlap on top of the foam. I used a mattress topper from Costco for the foam as it is memory foam and it has held up well. Total cost including a $50 sewing machine from eBay is less tha $300 — front rear seats and all 4 doors. Not show quality but very serviceable.
Old 10-12-2017, 06:31 PM
abe's Avatar
abe
abe is offline
abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.
Originally Posted by 49f3dls View Post
On my DYI I used canvas hand sewn on the springs and burlap on top of the foam. I used a mattress topper from Costco for the foam as it is memory foam and it has held up well. Total cost including a $50 sewing machine from eBay is less tha $300 front rear seats and all 4 doors. Not show quality but very serviceable.
I can attest to that as I was priveledged to ride in the Beast, both in the front and the back!
Old 10-13-2017, 08:32 AM
fordf348's Avatar
fordf348
fordf348 is offline
fordf348 is gaining momentum as a positive member of FTE.
A story on burlap seat back. When I had my seat upholstered the guy put canvas on the back of the seat. I told him I wanted it in burlap as original and what we had agreed to. He said burlap would disintegrate over time and he put the burlap in. That was 20 years ago and the burlap has disintegrated into dust as he said it would.
Ed
near Philadelphia
Old 10-13-2017, 08:57 AM
49f3dls's Avatar
49f3dls
Ed
near Philadelphia
But Ed - I will be dust in 20 years or less !
Old 12-04-2017, 02:01 PM
GoldCo's Avatar
GoldCo
GoldCo is offline
GoldCo is starting off with a positive reputation.
Exclamation help?
Cougar, how did the install go?
I just rec'd my Cartouche kit and am already a bit perplexed -- do you really have to remove the springs from the frame? They look to be pretty integrated, in that there are dozens of 'clips' which would have to be bent out in order to remove, and then presumably bent back in upon install, which means odds are pretty good that the 65yo metal would rather just snap off then bend.
The bottom isn't quite as bad (maybe) except that it goes in front and below the frame in the front.
I'm having a hard time envisioning the final product (which would help with the process), having never seen a finished seat. (Mine was just a rusty seat frame in a field.)
Got any pix or advice for me?
Thanks.
Old 12-04-2017, 02:13 PM
GoldCo's Avatar
GoldCo
GoldCo is offline
Arrow
so just found this photo in another thread...
...which makes me think you must leave the springs on the frame, since the vinyl goes over/around the bar on the seatback and also in front of the seat bottom??
Old 12-04-2017, 02:36 PM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
FortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud of
It isn't necessary to remove the springs from the seat frame.
This video might help:
https://www.lebaronbonney.com/video-...lation-006.htm
Old 12-04-2017, 04:45 PM
Cougar54
Cougar54 is offline
Thanks.
No springs need to be removed. I had a helper which was nice to hold the seats while I stretched the covers over the springs and new cushioning. I have about 10 pictures of the seat in progress. Here are pictures of the completed back and bottom. Oh, the hog ring pliers that come with the kit do work but they could use longer handles with some cushions. An offset head would have been helpful as well. If this is the only seat you recover, they will do the trick. If more recovering is planned, buy some nicer pliers.
Old 12-04-2017, 05:25 PM
GoldCo's Avatar
GoldCo
GoldCo is offline
thanks cougar
would love to see the "in progess" pix if it isn't too much of a hassle...
the video link shared above was helpful, except that it, too, has the springs separated from the frame. just looking for more clarity about where exactly everything goes when the frame is still involved.
Quick Reply: Cartouche Seat Kit
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
