1991 brake switch install question
Old Oct 10, 2017 | 06:56 PM
Caveman Eric's Avatar
Caveman Eric
Sorry for a small question. I replaced the brake/clutch bracket on my 1991 and accidentally dropped the switch before catching the direction it went on. If you have done this, you know one side has a complete hole for the post sticking out of the brake pedal arm and the other side is an open, U-shaped opening. Which side goes over the post first? (I think I need to loosen everything up again since I can't remove it from the plunger.)
The problem I am having is the brake light remains on, even though it appears there is no pressure on the sliding mechanism in the switch and I thought perhaps I installed it upside down?
Thanks, all.
joe cowan
Apr 1, 2010 09:23 PM
blue52f1
Sep 3, 2006 01:24 PM
broncofl
1966 - 1977 Early Broncos
Nov 23, 2004 12:35 PM
fordman300
Feb 9, 2004 08:59 PM
leonharu
Jun 26, 2002 10:03 PM
