stand alone 7.3 harness??
Old Sep 7, 2018 | 12:18 AM
f250rangerexplorer's Avatar
f250rangerexplorer
Any updates?
any updates on the project? Did the truck start/run or is it a dead project?
Old Sep 7, 2018 | 01:24 AM
robbv's Avatar
robbv
She started and ran I drove it around the block and parked it for the summer as it’s a winter project and I am just to busy in the summer to work on it when it’s 40+ outside.
In the next next month I’ll be getting right back in to the swing of things. The stand alone harness I made for the truck worked great all the gauges still work as well as the obd2 port still was able to read diagnostics and all the headlight and turn signals high beams still worked with the 7.3L switches
Old Oct 25, 2019 | 01:06 AM
robbv's Avatar
robbv
update on the harness
its functioning very well I've recently started to wire in the little things i kept in the harness like the cigarette lighter, the factory brake light switch and clutch switch.
my obd is connected to a edge cs programmer that shows me all my gauges like speed, EOT, MAP, MPH, VOLTAGE RPM etc
pretty satisfied with the hole thing
the factory gauge cluster still works great and i only have a ABS light on that i believe is just because the front sensors are unplugged
Old Oct 25, 2019 | 01:31 PM
AubieTN's Avatar
AubieTN
Wow, good to hear you’re getting close to completion of the electrical work. Hang in there and keep us posted on your progress along with some pics.
Old Sep 21, 2020 | 06:40 PM
wharthog's Avatar
wharthog
OK, getting time for an update. Looking forward to seeing just what is going on with your winter project.
Old Feb 13, 2021 | 11:50 PM
67Charger's Avatar
67Charger
Any updates or pics? I'm about to put a 2001 7.3 auto into a 62 F500...
Old Apr 12, 2022 | 07:39 PM
robbv's Avatar
robbv
Awaking this from the dead
Another update for this long lost thread. The trucks currently at my new house. It sat for 3 years put new batteries in it and it fired up first crank. Getting come 53” tires mounted and putting a flat deck on it and possibly a knuckle boom Hiab between the deck and the cab. Going to make it the ultimate picker / rat rod truck.
Old Apr 12, 2022 | 07:40 PM
robbv's Avatar
robbv
I think that swap will be pretty simple. Let me know how it went
ddonzella
Jan 31, 2025 11:39 AM
obsguy
Jul 18, 2024 07:42 AM
Longstroke
58
Nov 21, 2017 11:52 PM
earlybroncoboy
1966 - 1977 Early Broncos
Feb 1, 2006 09:44 PM
shortbed1
May 28, 2003 10:58 AM
