Ford 1992 Pedestal Heads
I have a 1992 EFI heart shape head with pedestal mount rocker arm bosses. I want to install 7/16 screw in rocker studs to mount 1.7 BBC roller rockers. Question is about pedestal mount preparation.
Do I need to have the machine shop drill & tap the pedestal as they are and assemble only the number one piston/valves/springs to see if I need to remove any from the pedestal top and how much. Don't mine doing it a few times. I can also figure the correct push rod length to order at this time.
Or maybe there is a safe amount I can remove from the pedestal top the first time to get started. I will be running guide plates that are .140" thick.
Also has anyone out there used a Crane rocker arm guide plate conversion kit (52655-2 that installes a 7/16 rocker stud with the stud bottom threads 5/16 that go into a stock 1992 EFI pedestal mount. This is going on a ford 300 4.9L motor. This build is a mild over stock that will be in the 5500 max RPM range, with an RV cam & 1.7 BBC roller rockers. Spring rate is stock spec's, 9.0 CR with stock still D dish pistons and block milled .020". May make 180 HP if I am lucky.
old28
10-13-2017 07:36 PM
fasthauler
01-08-2007 09:38 AM
78Buford
08-10-2005 12:55 AM
ballistic64
06-26-2004 09:17 PM
Want2Bfordman
04-10-2004 10:43 PM
