1973 F-100 P/S Pitman Arm:(Help ND)
ND can you please give me the part # for a p/s pitman arm for a 1973 F-100.I am in the process of changing from manual to power steering and was told my original pitman arm will not fit on the power steering gear box?I did not realize this had to be changed.
1971 F100/250 2WD from serial number M00,001 / 1972/79 F100 2WD Regular/Super Cab (1974/79) / 1972/79 F250 2WD Regular/Super Cab (1974/79) under 8,100 lbs. GVWR
1975/79 F150 2WD Regular/Super Cab.
No Ford dealer or obsolete parts vendor has any.
Well I found out today that the rebuilt p/s gear box I got from NPD does not work?The mechanic sad that it will not mount because it hits the manifold???The application stated it was for a 1968-1979 F100-350 W/Ford Gear.Part # F-3504-1. Were there more than one p/s gear box used on these trucks?This change over is slowly turning into a nightmare!
Well I found out today that the rebuilt p/s gear box I got from NPD does not work? The mechanic sad that it will not mount because it hits the manifold?
The application stated it was for a 1968 -1979 F100-350 w/Ford Gear, Part # F-3504-1.
No 1968 had Ford/Saginaw P/S. Some 1969's didn't have it either.
Ford/Saginaw P/S: 1969 F100/250 2WD & F350 from serial number D96,001; 1970/79 F100/250 2WD & F350.
Thanks ND for clarifying these gear boxes.I guess I had a bendix unit that came from NPD.As of now I am using a used Ford/Saginaw unit which mounted up with no problems which I bought mainly for the pitman arm!On the p/s diagram for these trucks it appears there was a spacer used where the pump bracket mounts to the block.Can you give me any information or part # on this spacer shown?
CARPENTER NOS OBSOLETE PARTS in Concord NC has 15= 800-476-9653.
Well,I finally got everything installed and truck drives very nice.Wish I would have had this done 20 years ago.But now I noticed a problem with the used gear box I had to use.It is leaking some around the flange where the adjustment screw is located of all places?I figured the first place would be a the bottom shaft where pitman arm mounts.Any ideas on what to do.The only rebuilt gear box I can find like I need is at Red Head and it is $300 plus $200 core charge?
