8 speed trans
Old Oct 8, 2017 | 08:34 PM
KR-Pete's Avatar
KR-Pete
8 speed trans
I probably missed this cause have not been very active here in a while, but a couple years ago there was talk of an 8 speed trans for SD maybe in 17-18. Any news on that lately?
Old Oct 8, 2017 | 08:54 PM
fordmantpw's Avatar
fordmantpw
A 10 speed should show up in the 2019 or 2020 model year.
Old Oct 9, 2017 | 11:49 AM
KR-Pete's Avatar
KR-Pete
Thanks. I wonder why the delay? It was first reported a few years ago that GM & Ford were working together on this project. Kinda hard to believe that.
Old Oct 9, 2017 | 02:05 PM
fordmantpw's Avatar
fordmantpw
GM and Ford worked together to build a 9 speed FWD transmission which is now starting to show up in GM cars. GM took the lead on this tranny. Rumor has it Ford is going to drop a gear and make it an 8 speed in their cars due to shifting issues. They also worked together on a 10 speed RWD tranny (Ford took the lead here) which was in the F150 (with the 3.5L EcoBoost only) for 2017, and across the board (except for the 3.3L) for the F150 in 2018. It's also in the Camaro ZL1 as well, it will likely show up in the GM half ton trucks next year.
As far as the Super Duty 10 speed, it will likely take some tricks from the light duty version, but will be vastly different due to needing to support 500 HP and 1000 ft-lbs of torque (plus more in the years to come).
Old Oct 11, 2017 | 02:24 PM
doczenith1's Avatar
doczenith1
While I like the idea of more gears and keeping the engine closer to it's peak power band I'm skeptical of all this gear changing with the torque management (or whatever it's called when the engine defuels during a shift). Perhaps they've refined it but it's very noticeable on my 2011 and very annoying when I'm aggressively accelerating unloaded.
Old Oct 12, 2017 | 06:17 AM
ruschejj's Avatar
ruschejj
It’s not as bad I you M shift. The 2011-2014 trucks have the most firm shifts in M mode, the 2015 and up are a little more sluggish.
I like to roll into the throttle in 1st gear and then go WOT while shifting 2-5 making sure the rpms stay between 1600 and 2200 but don’t go WOT until you feel the torque converter lock up. This gives me the best drag race using M mode. In D the shifts happen way too late and the torque converter doesn’t lock up until you’re leveling off at your cruising speed.
Louisville Joe
Dec 11, 2018 04:01 PM
Patatoe1
2009 - 2014 F150
34
Jan 14, 2007 10:46 PM
muscletruck7379
General Automotive Discussion
Dec 18, 2006 01:13 PM
BlackFX4Screw
2004 - 2008 F150
17
Mar 11, 2006 07:56 PM
JF5speed
Sep 29, 2002 06:55 PM
