Keypad is not controlled by the GEM, since you don't have one in your 03
It sounds like you might have hit a wrong button and disabled your unlock feature. Will have to read up on how to re-enable it...seen those instructions a few times in the tech folder. Just need to find them...
I have the same issue sometimes. I believe it is one of the buttons other than the last two. That explains why it always locks it. You can test that by letting the keypad go dark then hitting each button to see if one of them doesn't cause it to light up. That is my problem and I believe water or something got in behind the button pad. The middle button is faulty. For now I just made a code not using it so I dont get locked out. Worth a check.
Hey if you are that dedicated, help yourself to whatever you find in there. Just do it before I come outside because this is Texas and it's OK to defend your property here, not just yourself.
