Fuel pump question?
Old Oct 8, 2017 | 02:34 PM
Kurt G.'s Avatar
Kurt G.
Question Fuel pump question?
Okay I have a 292 in my truck and I have a tri-power system I'm going to put on it. Will the stock fuel pump work or should I get an aftermarket electric? I'm not sure what pressure the system should use, I will have a progressive linkage so not 3x2 all the time. Any ideas would be great. I'm leaning towards the electric but not sure.
Old Oct 8, 2017 | 03:26 PM
49f3dls's Avatar
49f3dls
I have a very low pressure electric pump in the beast but it is switchable. I only have a single carb and when running at speed especially going uphill the manual sometimes can’t keep up and it will stall. Switch on the pump and no problem.
Old Oct 8, 2017 | 06:19 PM
fish pond's Avatar
fish pond
Look in your manual, it might tell you gallons per minute(there will be a decimal in that number)and perhaps the pressure she will hold.
then you could check what your carbs require, maybe?
I am preety sure my book for my truck friend has her specs.
good luck.
Greg
Old Oct 8, 2017 | 08:18 PM
ALBUQ F-1's Avatar
ALBUQ F-1
What carbs are you using? Holley 94's? If so, go electric. 94's have little tolerance for high pressures, so you need a regulator for best results. To get flow on high demand, yet low pressure, and steady pressure, you want an electric.
Old Oct 8, 2017 | 09:01 PM
Kurt G.'s Avatar
Kurt G.
Yes I have some 94's. still need to get them working before I put the assembly on.
dongc1
Apr 20, 2007 08:58 PM
79 sb150
16
Jan 1, 2006 08:00 AM
radramrod2
Apr 19, 2005 11:29 PM
pissed off in mn
Dec 7, 2003 09:36 PM
Jag Red 54
Oct 30, 2003 09:21 AM
