Help ! 460 Heads Selection
Old Oct 5, 2017 | 12:42 PM
GLR's Avatar
GLR
More confused than usually. Have a stock 1987 F250 460 carburetor. Used mainly for pulling car trailer, traveling back and forth NY to VA. Upon removal, heads don't look too healthy. E6TE code on heads. Having trouble finding re-man heads. (Don't want to get into aluminum ones). Any suggestions as to what else/years would work ok. EFI heads have different rocker covers.
Thanks in advance.
Old Oct 6, 2017 | 12:34 AM
cbakker's Avatar
cbakker
If you are looking for simple and your heads are re usable, just clean them up put new valve seals in, open up the exhaust ports a tad and you will be doing well. Swap out the Cam timing set for the straight up timing version(order one for an 88-98 460.
Old Oct 6, 2017 | 07:57 AM
GLR's Avatar
GLR
Heads will need new exhaust seats and ex. manifold surfaces on heads are badly corroded. I'll try to get to a local machine shop today.
Old Oct 6, 2017 | 01:07 PM
cbakker's Avatar
cbakker
If possible have them plane the exhaust ports as well as the manifolds to match. Get a new set of Fel-pro gaskets.
Old Oct 6, 2017 | 04:46 PM
GLR's Avatar
GLR
Back from the machine shop. He agreed that the heads are pretty rough. Will magnaflux 1st, then see about milling the surface where the exh. ports are, then dunk and new seats.
Had a chance to get a pair of DOVE heads a year ago.....but, didn't need them then...
austynn2001
WTB - Parts & other
Aug 23, 2016 10:11 AM
cortina219
Aug 21, 2013 08:17 PM
rye2842
Oct 9, 2007 08:21 PM
f100reborn
Mar 17, 2005 08:32 PM
timhoe
Nov 15, 2000 01:18 PM
