Engine ID
Old Oct 4, 2017 | 07:52 AM
reddogracing's Avatar
reddogracing
Engine ID
In a 1966 ford dump truck. Say it is bliwn considering worth to rebuild or replace engine all else is good shape.
Old Oct 4, 2017 | 08:25 AM
KULTULZ's Avatar
KULTULZ
Question
It appears as a 272/292, not OEM for a 66.
Can you post a VIN so ND can break it down for you?
Old Oct 4, 2017 | 01:30 PM
reddogracing
it is something i am looking at online. Seller says it all original DRW 1966.
I assume from my 460 exprience that I could drop a 460 with bellhousing in there if i fab the mounts. If not adding a trans would nout be an issue since it is rwd
Old Oct 4, 2017 | 01:54 PM
KULTULZ's Avatar
KULTULZ
What is the size/series of the truck?
If you post the VIN we can see what engine it was assembled with.
Old Oct 4, 2017 | 02:44 PM
gittinwidit's Avatar
gittinwidit
If it's a manual you can add a bell, clutch and roll. Can't tell from the pic? Actually you can drop any combo with a 460. Just can't use this tranny if it's an automatic for bell housing will be cast onto tranny and wrong bolt pattern.
Old Oct 5, 2017 | 02:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
In a 1966 ford dump truck. Say it is blown considering worth to rebuild or replace engine all else is good shape.
Post #3: Seller says it all original DRW 1966
BS! The seller doesn't have a single clue!
This is a Y block, Y block valve covers are retained to the heads with two studs per side that poke thru the covers.
Y blocks have the distributor behind the carburetor. No 1965 and later truck came with one of these engines.
1965/66 "dump" truck with DRW, depending on if it's a F350 or F500/750, could have:
Either a 352 FE V8 engine (F350), or a 330 2V Medium Duty; 330 2V Heavy Duty; 361 2V; 391 4V FT V8 engine (F500/750).
Both the FE and FT valve covers are retained to the heads with 5 valve cover bolts per side, the distributor is in front of the carburetor.
(sigh) Most ebay and craigslist sellers haven't a single clue what parts fit, even if they are brand new w/a part number marked on them.
Casey Hope
15
Oct 7, 2017 12:18 PM
Dace
Jul 16, 2015 10:26 PM
lvin4jc
20
Dec 10, 2011 09:01 AM
pumbakz
May 13, 2004 09:44 AM
Erwin
Feb 23, 2000 08:30 PM
