2002 F-350 SRW Blowing Fuse #18 - Brake/Turn
I have searched and seams this is a common issue with different causes. I have determined is fuse 18 will blow with either turn signal, hazards, or the brake lights on. It doesn't always blow immediately. Once it blow when I stated the truck with the hazards on. Usually will blow shortly after I start drivinng
I have read it could be the multi-function switch in the steering column or the brake position switch.
I disconnected the tail light harness and the fuse does not blow. I reconnected the harness and removed the stop\turn bulbs and the fuse does not blow. My thinking is if there were a wiring issue with a wire shorted to ground removing the bulb would not change the issue.
Could it be a bad ground (high resistance) causing high current?
Does anyone know where this circuit is grounded?
I have read it could be the multi-function switch in the steering column....
...or the brake position switch.
Thanks for the feedback. I found the issue to be the wiring harness for the trailer plug. I removed it and the issue of blowing fuses went away. I found corrosion where the harness plugged into the 7 pin receptacle. Also the 4 pin receptacle was corroded. The harness must have been drawing some current and by adding additional current with the brake/turn bulbs put it over the 20 amp fuse capacity.
The factory trailer adapter should prevent a short in the trailer feeds from taking out F18, it's isolated by relays and the trailer turn/stop lamps are fed from a different fuse. The only way the trailer circuits can take out F18 is if they were wired in post-factory or if there's a cross-circuit between the primary and the trailer wiring circuits.
cflintstone
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
08-11-2015 11:37 AM
mr.big
1997 - 2003 F150
01-24-2010 10:07 AM
bgblktruk
1978 - 1996 Big Bronco
05-21-2002 01:02 PM
