7.5 Engine Coolant Leak Information
Old Oct 2, 2017 | 09:08 PM
Rennisreaper's Avatar
Rennisreaper
I appear to have a coolant leak on my engine, under the throttle body. Not where the radiator hose goes to, but the larger gasket below that radiator hose neck. Also not the smaller gasket directly underneath where the air piping goes from the air box. It appears to be a very large seal the liquid is sweet and my coolant resivior was filled the other day and now is bone dry. Seems to pool on top of the engine. Again not the smaller seal directly below throttle body nor the small seal below the radiator hose neck going into the engine. It appears I am going to have to remove all the wires and throttle body on top of the engine just to get to this seal. So I am curios where I would get information to remove all the components replace the seal and reinstall all of them as it seems very extensive. I have the shop manual and shop electrical manual. Neither cover the 7.5 engine in the information I require to do a decent job. Is there a site or manual with the information I require?
Old Oct 2, 2017 | 09:22 PM
ChRoNo16's Avatar
ChRoNo16
A chiltons manual available at any auto parts store for about 25 bucks has everything you need. step by step, diagrams, all of it.
Old Oct 2, 2017 | 09:31 PM
Rennisreaper
I'll give mine a look. Didn't think of it seeing as my factory ones were very clear.
c04678
6.7L Power Stroke Diesel
Mar 17, 2017 05:53 PM
Breaker Breaker 3-3
Mar 16, 2010 10:35 PM
powerstroke1869
Dec 18, 2008 08:21 PM
clux
May 1, 2006 09:54 AM
whatdyisit
Nov 21, 2004 08:47 AM
