Stock 460 what heads?
Selecting cylinder heads can be a hard task. What your selection comes down to is what you want to do with the engine. Edelbrock makes a few different versions of the 460 head, both in smallport and cj port. From my research, I believe that the edelbrock cylinder heads, both versions are nearly the worst flowing aluminium cylinder head on the market. I have done sets of cast iron heads that flow much better. Btw, smallport heads will deliver more torque on the low end, when combined with a proper cam than a cj head. Don't expect to just bolt on a set of these heads and expect a big power increase without changing other things. The compression ratio will increase, and you can calculate how much by using a online calculator.
Well what are good heads that I can run that will allow me to have good all around power. Because right now I have a 296 duration cam 520 lift. Strait up timing chain. And I want the 72cc chambers to raise the compression from 8.1 to ? Just curious on what it would raise it too. Would there be a way you can do it for me because those calculators never work for me
V10man
12-30-2021 10:48 AM
BIG-COUNTRY
02-04-2007 01:34 PM
hillbillyk
05-15-2001 07:19 PM
