T/C position sensor question
Old Oct 2, 2017 | 11:18 AM
Caveman Eric's Avatar
Caveman Eric
Hi all.
I'm trying to track down minor problems while waiting for parts to arrive. One problem is the dash lights for the transfer case. I have a 1991 with a five speed. The bulbs all work (first attempt cleared that up). The shift lever goes into all positions. When moving from 2H to 4H, no "4X4" lights come on. When going from 4H to 4L, the low range lights DO come on. I'm wondering if that is a sensor issue. I will crawl up there if there is encouraging news from anyone. Thanks.
Old Oct 2, 2017 | 02:17 PM
88XLTLariat's Avatar
88XLTLariat
Yes, the sensor on the transfer case has to be adjusted to illuminate dash lights.
Old Oct 13, 2017 | 04:16 PM
Caveman Eric
Does anyone have an illustration of how to adjust the sensor? Or an electrical diagram so I can test the leads on the switch? It looks like a simple screw in switch, is it more economic to just replace it? 1991 F250.
Thanks again.
Old Oct 14, 2017 | 02:43 PM
Caveman Eric
Discovered the sensor is a two position switch number E6TZ-7E440-A on the body. I tested the switch and it works. I ran a circuit through it in the half plunged position and one probe completed the circuit. Pressing harder I got the other probe to complete circuit. This has a two contact pigtail on it that joins to a four prong pigtail. Three of them appear to be connected and I cannot get any kind of circuit through the fourth. Is one of these an unused pin? Does anyone have a picture of this circuit? Thanks.
Old Oct 14, 2017 | 05:18 PM
subford's Avatar
subford
This one should be what you have:
Old Oct 14, 2017 | 05:57 PM
Caveman Eric
Thanks. This answers many questions.
You are a wonderful source of illustrations. Are these available for purchase? I hate to be a bother.
Eric
Old Oct 14, 2017 | 06:13 PM
subford's Avatar
subford
Yes they sell them on ebay.
1991 Ford F-150 250 F250 350 Bronco Truck Service Shop Repair Manual Set W EVTM | eBay
sparks717
Apr 24, 2026 01:14 AM
D Ray
Aug 10, 2010 09:41 PM
wingerpaul
Sep 17, 2008 03:59 PM
Bronco2guy
Bronco II
Feb 5, 2003 12:30 PM
tda424
1997 - 2003 F150
May 11, 2002 10:56 AM
