Remove Gear Stick
Old Oct 1, 2017 | 06:19 PM
BGF100's Avatar
BGF100
Remove Gear Stick
Hi, I am thinking of removing the transmission / gear box.
Can't find an article on it.
How do I take the stick lever off?
Thanks,
Old Oct 1, 2017 | 08:39 PM
Harrier's Avatar
Harrier
It's pretty simple. Unscrew the shift ****. Then at the base unscrew the cover. There is a pin on the left side that you have to be careful of. Pull that out (It is in loosely) and the lever will come right out.
I highlighted the pin to watch for. Careful not to lose it.
I think part 7220 is what unscrews in the base.
Old Oct 1, 2017 | 08:40 PM
Harrier's Avatar
Harrier
Actually, you don't need to unscrew the shift ****.
Old Oct 5, 2017 | 09:54 AM
BGF100's Avatar
BGF100
Diagram
Hi, thanks, where did you get the diagram from?
Thanks,
Old Oct 5, 2017 | 05:55 PM
BGF100's Avatar
BGF100
Hi, I tell you what that cover doesn’t just unscrew. I have left it soaking in WD40. Hopefully it will release? Thanks,
Old Oct 5, 2017 | 08:24 PM
Harrier's Avatar
Harrier
That diagram is from the Ford Master Parts Catalog
https://www.hipoparts.com/1948-56-fo...ts-catalog-cd/
It is well worth the minimal cost.
I just ran out and checked mine. The 7220 part should unscrew. It is probably been in the same place for 60 years so it might take a bit to loosen it up.
Old Oct 6, 2017 | 09:59 PM
49fordv8f4's Avatar
49fordv8f4
There should be two flats on the flange of the cap for a wrench. The cap is not very thick, so a pipe wrench or water pump pliers can pinch it tighter on the threads and make removal difficult. A large adjustable wrench or a wrench that fits the flats will work better. You can tap all the way around the flange with a hammer to loosen any rust. You should have the stick in neutral when you pull it out.
Mark
Old Oct 7, 2017 | 01:46 AM
BGF100's Avatar
BGF100
Hi, I got it to come loose this morning. The cover is now looking a bit wirse for ware. However, I think it can be tidied up.
Thanks,
Old Oct 7, 2017 | 07:26 AM
Harrier's Avatar
Harrier
Glad you got it off. Often, the little things cause much heartache.
Old Oct 7, 2017 | 10:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Borg-Warner T-98: Shift lever retainer cap (8MTH-7220) threads off/on.
sailorman3
Nov 30, 2011 08:07 PM
hrp77573
May 16, 2010 03:36 PM
r0n1n
Appearance & Dress-Up
Feb 14, 2006 07:35 PM
Tacoma Ron
Jul 29, 2003 11:48 PM
