U-joint installation?
Old Oct 1, 2017 | 01:02 PM
3twinridges's Avatar
3twinridges
about to install NOS u-joints, is it worth investing the money for the u-joint cap press or will a socket and hammer work equally as well? Which way should the grease fittings face?
Old Oct 1, 2017 | 01:13 PM
raytasch's Avatar
raytasch
Believe Nothing
A vice is the only 'press' I've ever used and I have done a few.
Old Oct 1, 2017 | 02:01 PM
CharlieLed's Avatar
CharlieLed
Couldn't afford a vise...used c-clamps and a socket.
Old Oct 1, 2017 | 02:27 PM
Gertie-The '49 F2's Avatar
Gertie-The '49 F2
Agree with Ray on the vise. At the family machine shop, we used to do a LOT of drive shaft mods. for pick-ups, and we just used one of the big vises on our welding table along with a slug of cold-rolled steel as the punch, and another slug drilled out to slightly larger than the cap. To this day, I can change out a u-joint in jig time.
Old Oct 1, 2017 | 05:35 PM
matthewq4b's Avatar
matthewq4b
The correct position of the grease zerk is so that it is on the compression side rather than tension side of drive yoke. Other than that install the joint so that it is in the most accessible position for servicing.
Old Oct 2, 2017 | 05:29 PM
Dirtbag's Avatar
Dirtbag
U-joint grease zerk goes towords the drive shaft. If it was to be placed away (outwards), most times you can't get a grease gun on it.
Old Oct 2, 2017 | 08:13 PM
EBEAR's Avatar
EBEAR
Any shop vise and assorted sockets work fine . The idea of hammering is not the best it's very easy to lose needles .
Gheu7172
Aug 12, 2017 11:16 AM
1970XL351W
Jan 6, 2014 11:17 AM
oricle
Jun 9, 2005 10:35 AM
Gwilkrrs
Aug 13, 2004 03:04 PM
classicfordluvr
Aug 6, 2002 05:32 PM
